1999 V70T5M56 timing belt job P0014 code, pernicious ECM 644A Topic is solved
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
Don't trust the FAE brand?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
jmartin919
Never mind - T5.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- Has thanked: 2200 times
Correct. Don't trust the KAE brand if you are talking Fuel pump relays.
jmartin919
FAE makes a cam shaft position sensor for 1999 V70 but not for the T5.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
I do not think these sensors differ between T5 to NA AFAIK.jmartin919 wrote: 20 Sep 2023, 16:58 FAE makes a cam shaft position sensor for 1999 V70 but not for the T5.
2008 S60 2.5T Auto (Sold)
Sent a tech support request to Autel on this
Units of camshaft shifting angle show as grad KW?
Asked them to describe difference between the above and the . Nominal cam shifting angle
See pic
See pic
jmartin919
I'm just going by the fitment notes for each manufacturer. T5 not listed for FAE.yanga001 wrote: 20 Sep 2023, 19:20I do not think these sensors differ between T5 to NA AFAIK.jmartin919 wrote: 20 Sep 2023, 16:58 FAE makes a cam shaft position sensor for 1999 V70 but not for the T5.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
yanga001
@Abscate, on the volvo website it shows that these are the same through the P2 series. FCP differs from the volvo oem parts website. Any chance you have a spare P2 sensor you could stick in temporarily to see if it works?
I’ve got a P2 and another turbo P80 but it’s a decent teardown to get to the sensor on the RN block.
AUTEL responds promptly
Dear Dr Smith
Thank you for reaching out to us.
Question 1: Yes, it should be in degrees.
Question 2: The "Shifting angle of the camshaft" refers to the actual measured difference between the camshaft position and the ideal theoretical position. On the other hand, the "Nominal camshaft shifting angle" refers to the ideal camshaft position set by the manufacturer. In simple terms, the former represents the measured value while the latter represents the theoretical design value.
Thank you.
- 18 Replies
- 2124 Views
Last post by dikidera
- 5271 Views
Last post by jimmy57
- 38 Replies
- 12381 Views
Last post by prwood
- 303 Replies
- 37428 Views
Last post by bmdubya1198
- 25 Replies
- 6826 Views
Last post by wizechatmgr
