I've looked onlne. The socket we need is 19 mm/34" split socket. There is one shown but when I clicked it only the standard fully closed socket comes up.
Any suggestions?
can't find socket to replace coolant temp sensor
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I just used a grinder to cut a slot into a cheap sacrificial socket. Worked with no issues.
1999 V70 GLT
1999 V70 GLT
You can get a 19 mm in flare or. Even use a good tolerance open end to crack that sucker
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
You can buy a set of deep sockets from harbor freight. Cut a slot in the one you need. Then take the whole set and exchange it for a new one. No questions asked. No receipt. I've literally done it with pointing and eyebrow raises.
That’s cold….ZionXIX wrote: 20 Sep 2023, 20:42 You can buy a set of deep sockets from harbor freight. Cut a slot in the one you need. Then take the whole set and exchange it for a new one. No questions asked. No receipt. I've literally done it with pointing and eyebrow raises.
Pete, I stuck my 19 mm flare in my travel bag then realized PeteB in MN is a long way from Pete in CT
This road is well paved with good intentions …
Lisle 12330 should work
- ZionXIX
They should never have placed a lifetime warranty on all hand tools. I personally am very pleased with the "Quinn" brand of sockets. They don't feel cheap like the "Pittsburg" line up and it's like $20 for a set of 1/2 inch deep sockets.abscate wrote: 21 Sep 2023, 06:24That’s cold….ZionXIX wrote: 20 Sep 2023, 20:42 You can buy a set of deep sockets from harbor freight. Cut a slot in the one you need. Then take the whole set and exchange it for a new one. No questions asked. No receipt. I've literally done it with pointing and eyebrow raises.
