2006 S60R Transmission Drain and Fill
Ethan5150
Year and Model: 1994 850 Turbo
Post by Ethan5150 »
Hi folks, I recently purchased an S60R with 82K miles on it. The tranny has never been flushed but the fluid looks to be in decent condition (see here: https://donofriocreative.com/s60r-fluid.mp4) I've read a bunch of the threads about flushing and drain-n-filling and I'm thinking I want to go the drain-n-fill method. Someone mentioned doing it at the same time I change my oil 3 sequential times is a pretty good way to go.
So my questions are as follows:
1) Can I just use Mobile ATF 3309 (https://amzn.to/3PpHtfs)?
2) Approx. how many quarts will drain out each time?
3) Is this really as complicated as people are making it sound? My mechanic says he's done plenty of drain-n-fills and you basically just make darn sure the volume that comes out is the volume that goes in. Am I missing something here?
Thanks folks, I appreciate your input! 🤙
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Yes, i think 3.6L (sorry dont know freedom units too well), just do amount out to in.
Fluid is a bit brown, remember this stuff is red going in.
It is a good preventative measure especially on the R.
2008 S60 2.5T Auto (Sold)
Has thanked: 293 times
Been thanked: 766 times
Yes on the 3309.
Looks like you're aware of this already but: your car has the TF-80SC transmission which for checking fluid level has the two-stage drain plug as opposed to a dipstick (there isn't a dipstick). Making sure you put back in exactly the same amount will definitely hold the status quo, but I do like to check the level the complicated way in a new-to-me car to make sure it has the right amount to begin with.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Ethan5150
Post by Ethan5150 »
Thanks everyone - and what about the Mobile ATF 3309 - is that the correct fluid?
erikv11 wrote: 14 Sep 2023, 00:19 Yes on the 3309.
Yep, that’s a good fluid choice.
'06 S60 R, 197k
XC70Rider
Year and Model: 2007 XC70
Has thanked: 35 times
Been thanked: 41 times
Post by XC70Rider »
Ethan5150 wrote: 16 Sep 2023, 14:19 Thanks everyone - and what about the Mobile ATF 3309 - is that the correct fluid?
After trying several ATFs I am stuck with Volvo Original ATF. It comes in 4 liters. Mobil 3309 will suit it needs but it is thinner than the original. I started getting smoother shifts after doing 2 drains of Volvo ATF. I got 6 quarts of Mobil 3309 that I haven't touched in 3 years.
Ethan5150
Post by Ethan5150 »
Awesome, thanks guys - great info!
