Robert has had the head off his 850 R twice for valve seals, and it has something north of 450k on the bottom end. Once you have the engine opened up you'll be able to tell better how deep and how many, but a minor scuff or 2 shouldn't be a big deal.yanga001 wrote: 18 Sep 2023, 22:59 Took a scope to my two spare engines for the 98 v70. Both engines clearly show all the cross hatching however there are some singular scratches on the wall. None of the scratches look that deep on the scope however it does show a bit of wear. I am thinking that both perspective engines would need a valve stem seal job.
If the cross hatching is clear across all walls of the cylinder then would a handful of sidewall marks be something to be worried about?
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Thanks for the advice fellas. From my scoping there was zero rust in the cylinders nor any foreign debris. The scratches i saw seemed superficial and did not appear to wear through the cross hatching. I know i had an oil burn problem on one NA engine but i suspect it was caused by terrible valve stem seals. Ill crank the cars and do a compression test when time permits and make a decision based off that.
2008 S60 2.5T Auto (Sold)
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I've been chasing a recurring CEL for the xc90 since finishing the head rebuild. I though I had advanced the exhaust cam 1 tooth too much. I keep getting an "cam position sensor exhaust signal too high" in Vida. I move the cam back 1 notch with no change. After some googling decided to check the vvt solenoid. It was siezed. After a thorough cleaning and clearing the codes I have not seen it throw a CEL in 2 trips. Finger crossed its fixed! It's an easy job and I was able to do it without snap ring pliers.
- Has thanked: 1613 times
- Been thanked: 4078 times
Well, tough week. Did a big trip up to Albany to recover parts and such, and got into a multi car wreck in CT that totalled Shagg. Still runs but not driveable.
No pictures until I work my way through
Denial anger negotiation acceptance
Present state : sadness
Physical injuries: None. Volvo armor did its job admirably
duke1
- Year and Model: 855 1994 10v
- Has thanked: 416 times
- Been thanked: 34 times
sad but you walked away lucky you like volvos and at worst you have a parts donor,bummed for you though.abscate wrote: 23 Sep 2023, 08:06 Well, tough week. Did a big trip up to Albany to recover parts and such, and got into a multi car wreck in CT that totalled Shagg. Still runs but not driveable.
Wrecked one week after I get her T5 twin back on the road.
Three great years and 33,000 miles on a dime
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Shame about Shagg, but more importantly, you're ok !
1999 V70 GLT
1999 V70 GLT
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
WHOA this is not good! Lucky no injury. Was it a stacked-up traffic sort of thing?
Perfo-fecto!
