2008 C30 coolant leaking over passenger wheel well **solved**
Pretribrapper
- Year and Model: 2011 C30 2.0 T5
- Has thanked: 51 times
- Been thanked: 6 times
Only happens when I drive it. If I start and leave it idle then nothing. Some coolant was leaking out overflow tank right out of the relief hole. I thought the cap may be the culprit so I replaced the cap and nothing got better. Still spraying out relief hole up top. Thoughts?
- 20230923_204219.jpg (603.18 KiB) Viewed 245 times
- 20230923_204235.jpg (205.41 KiB) Viewed 245 times
- 20230923_204225.jpg (397.04 KiB) Viewed 245 times
- 20230924_211610.jpg (239.41 KiB) Viewed 223 times
- 20230924_211743.jpg (178.38 KiB) Viewed 223 times
- 20230924_211726.jpg (132.65 KiB) Viewed 222 times
- 20230924_211813.jpg (248.04 KiB) Viewed 222 times
Pretribrapper
Ok this is embarrassing. Long story short I needed a coolant cap. All better.
