VIDA Dice Program new switchblade remote without PIN
dreiher2
Year and Model: 2005 XC70
Post by dreiher2 »
I was able to find a new remote switchblade key for $60. It did not come with a PIN. Can I program the remote with VIDA Dice without a PIN?
VIDA charges $70 for the flash code to program a remote. $35 for flash code to program the chipped key.
I asked them for one and they did not get back to me. I asked to return it for my money back.
Can the remote be programmed with no PIN?
- Don
dreiher2
Post by dreiher2 »
FYI 2005 XC70 P2
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
vtl
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
You need a bar code on the packaging for the key.
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
As vtl mentioned you need packaging for programming even if going for VIDA sub way.
Its flashing software based addition thing which requires active VIDA sub online as you discovered. You need two codes from the original packaging to program it IF it is brand spanking new not used as its then not working as is even with barcode existing due how its operates.
dreiher2
Post by dreiher2 »
OK! Thanks everyone. I sent it back for a refund.
Also. . . UHS hardware offers a switchblade key with codes. . . but they are back ordered.
https://www.uhs-hardware.com/products/2 ... 2t-apu-oem
Have any of you used one of those? It says OEM factory refurb with PIN code.
- Don
vtl
Post by vtl »
A few years ago a blank ID48 chip was $1.5 or so. Transponder chip can also be reset and reprogrammed to Volvo specs in order to accept a new key. I don't see why a refurb won't work.
