What is the normal duty cycle for the fuel pump ?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
No PEM on 2001-2002
As for the engine stall, very scary. It happened on the highway and even once on the city highway with no way to pull safely. All stalls happened when the tank was low, in warm summer days, after having driven for 30-60 minutes on highway. The engine would simply die all of a sudden, strangely mostly when slowing down with the traffic, with all electrics still working. Most times I could simply switch to N then turn the key and restart the engine while still rolling, then switch to D and keep driving without a single problem. Another time it would not restart until I removed the key from ignition (car was stopped). Besides these moments, the car would perform perfectly at all speeds and rpm.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Same for the 2001 V70XC?
xHeart
The ECM Parameters only list Fuel Tank Pressure. Does it mean PEM is missing OR failed?vtl wrote: 10 Dec 2020, 18:16 Yes. You can double check it in VIDA: ECM has the "Fuel pressure" parameter if PEM is present.
The Fuel Tank Pressure value at POS II is -0.25.
A quick search, the PEM module for 2001 V70XC with emission "D" and chassis range is https://parts.volvocarslisle.com/p/Volv ... 42823.html -- check the tab "WHAT THIS FITS".
