Ok. I'm lost.
Losing coolant. Not sure how.
Initially the coolant was leaking out the overflow tank. I replaces the cap and it seemed to fix rhe issue. Then, I noticed I was still losing coolant but no Idea where.
I did coolant pressure test and no issues.
I did exhaust gas test and no issue.
Mechanic said he thinks it is leaking out bottom of my actual reservoir tank but he said it was leaking from a spring in the reservoir. There is no spring in the reservoir and the cap was replaced so that new one is good.
Anyone know if it actually could still be the tank itself?
2008 c30 coolant loss
Pretribrapper
- Year and Model: 2011 C30 2.0 T5
- Has thanked: 59 times
- Been thanked: 9 times
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Check the T / Y tube. There are two different ones depending on whether it's an auto or manual transmission. The plastic T or Y connection joint acts as a pressure clamp so when it cracks there will be a slow leak without obvious signs. It also bury in the middle of engine so you can't see the hose readily. Had I known the plastic was a clamp I would have carefully removed it and just use regular hose clamps and reinstalled. We opted for the silicon hose set which in hindsight was costly besides we didn't have time to change the others so it's sitting around.
Pelican has some useful DIY guides.
https://www.pelicanparts.com/techarticl ... o_Tech.htm
https://www.pelicanparts.com/catalog/Su ... atalog.htm
https://www.pelicanparts.com/More_Info/ ... 2&DID=6641
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
If it is the tank you should be able to see it.
I just sold a 2008 C70 and based on risk of catastrophic octopus hose failure and overheating/engine failure I changed all the hoses and thermostat plus the housing. Worth considering if planning to keep the car, not a bad DIY job.
If the octopus hose is leaking under the intake it’ll be hard to tell as it is buried under a lot of stuff.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 888 Views
Last post by 93Regina
- 38 Replies
- 12226 Views
Last post by mrbrian200
- 1052 Views
Last post by Pretribrapper
- 357 Views
- 1498 Views
Last post by red0161
