1998 S70 Auto HVAC is going crazy, suddenly blows full hot
Has thanked: 2200 times
Been thanked: 1852 times
First link says 9134784 was superseded by 9171552. 2nd link says that in turn was superseded by 9171595 and fits 98-04 P80's.
https://www.volvocarstorontoparts.ca/p/ ... 34784.html
https://www.volvocarstorontoparts.ca/p/ ... 71595.html
I know Volvo websites can be wrong these days, but could the variance be a programming issue and not a part number issue?
Been thanked: 4065 times
A 1998 ECC controller won’t work in a 1999-2000 , in my experience
That is the issue here. What Volvo says and reality. Thanks Abscate!
clarkerussell
Year and Model: 1998 S70 GLT
Has thanked: 20 times
Been thanked: 4 times
Post by clarkerussell »
After a run to the Pick-a-part for a few door lock mechanisms, I now have 2 ECC controllers. One is the 9134784 and the other is the 9171595. Both were pulled from 1998's.
How does one test that they are actually functional?
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
clarkerussell wrote: 12 Oct 2023, 21:45 After a run to the Pick-a-part for a few door lock mechanisms, I now have 2 ECC controllers. One is the 9134784 and the other is the 9171595. Both were pulled from 1998's.
Put it in and give it a go - that’s about the best way.
And correct, 98 ECC is different than 99+
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
I would match part numbers. I think wizechatmgr torched an ECC controller on a bad swap once
Now you have me thinking. I have several ECC units which I have pulled over the years especially when there were 50% off sales in PnP junkyards. So far never needed one, but now I even mention it is will likely be the next failure on the 'R'. I need to check what I have and part numbers. I think there might even be a 850 ECC somewhere and I think I have the controller body for an MCC unit for a 98? Buttons went to help another MVS member as their car had broken buttons when bought.
V50M66
Post by V50M66 »
abscate wrote: 14 Oct 2023, 10:07 I would match part numbers. I think wizechatmgr torched an ECC controller on a bad swap once
I could see that with putting a 99+ module in a 98. Tried it and the car freaked out. However, the ECC I tried to diagnose my climate issues was a different part number (out of a part out 98 S70) and it worked fine
I was thinking about this some more as the part numbers didn't seem right to me, and then it finally dawned on me. Our ECC units north of the 49th are in Celsius not F. So our part numbers are to the US. Strangely the 2 part numbers I have are:
9171635 (sup: 9171594)
and
9171799 (sup: 9459769)
Again on the Volvo OE parts sites these are listed on fitting ALL 98-04 P80's for both part numbers??
V50M66
Post by V50M66 »
scot850 wrote: 18 Oct 2023, 18:49 I was thinking about this some more as the part numbers didn't seem right to me, and then it finally dawned on me. Our ECC units north of the 49th are in Celsius not F. So our part numbers are to the US. Strangely the 2 part numbers I have are:
and
Yeah, number differences for Canada and ROW are down to C vs F printings on the face.
I don't know what's up with the parts sites - '98 and '99+ units are totally different and incompatible with each other.
