P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
@ BlackBart
That's Buachaille Etive Mòr 'the great herdsman of Etive' a mountain at the head of Glen Etive which is 3350 feet high
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
P80GLT
Post by P80GLT »
matthew1 wrote: 16 Oct 2023, 07:14 Spoilers do more to tastefully transform the look of P80 and P2 wagons than anything else.
I prefer the sleeper look of my V70 without the spoiler and roof rails
2010 XC90 SE...SOLD
2005 V70 2.5T SE
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Krons wrote: 15 Oct 2023, 17:59
MoVolvos wrote: 11 Oct 2023, 21:34 (EDIT: Sorry P2. Was reading and didn't change over and started posting)
Changed the oil in the 00 S70. Purchased 2 case of 3 gallons per case of Rotella T6 15W40. Someone on BTOG liked using the 15W40 and said he would dilute with the 5W40 if the weather was cooler. Was using Swepco 306 15W40 for years in CA. The 98 S70 T5 (circa 2012) was so smooth, quiet and robust when you exercised the turbo with the dino Swepco. Then accidentally purchased the Rotella T6 one day at $13 a gallon and put it into the 03 Odyssey. Because of the price and was in hurry to do the oil change didn't looked at or mattered which oil. I took a look at the bottle when the van ran really really smooth. Cost made me change over to Rotella.
I think the last change was using Costco's 15W40 dino diesel oil and the car responded well. Even got over 31 mpg on a 140 mile trip on the freeway. Trip computer use the mpg and calculated 615 miles till empty.
Since we are getting into cooler weather I decided to add one quart of Castrol 5W50 just in case it will be too thick. Car is quieter so the tire noise is more pronounced otherwise smooth running. Will see if I get over 32 mpg on the next 140 mile run.
I’ve been using 15w40 diesel oil as a top off for my P2s. I know it dilutes the 5 gallons of whatever I’m using but way cheaper than buying individual quarts. I never run past 5000 miles so likely any oil of correct viscosity would work for me.
Did you mean the 15W40 as a top off to thicken? If not what heavy weight oil are you diluting?
MoVolvos
Post by MoVolvos »
P80GLT wrote: 16 Oct 2023, 19:21
That's the cleanest V70 I've ever seen. If the interior is as new as the exterior I would purchase that any day! Always like the clean sleeper look. Pegs, Thors & Orpheus are my top 3 rims.
P80GLT
Post by P80GLT »
MoVolvos wrote: 16 Oct 2023, 23:06...If the interior is as new as the exterior I would purchase that any day!
Sold, when can you collect it? :D
Wheels are original and have never been refurbished
2010 XC90 SE...SOLD
2005 V70 2.5T SE
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
MoVolvos wrote: 16 Oct 2023, 22:46 Did you mean the 15W40 as a top off to thicken? If not what heavy weight oil are you diluting?
I too was topping off with C3 diesel spec 15w40. Engine oil in a last few years before the engine rebuild was Red Line 10w40. Valve stem seals were compromised because of age and mileage, they were seeping oil quite a bit, up to 20-25 oz between oil changes at 5k miles intervals, which eventually caused a heavy cement-like deposits in combustion chambers and pitted exhaust valve faces.
Too bad white block design does not permit easy valve stem seals replacement.
Been thanked: 818 times
vtl wrote: 17 Oct 2023, 08:12 …
Too bad white block design does not permit easy valve steam seals replacement.
So so true.
MoVolvos
Post by MoVolvos »
P80GLT wrote: 17 Oct 2023, 04:26
Excellent but not sure when I'll hit the Jack Pot. A left hander sure will make it one of kind here. I wonder if I'll be too old by then to learn to drive safely in the passenger seat :lol:.
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Usually 5qt of 5w30 High Mileage Full Synthetic and 1qt 15w40 Mobil Delvac 1300 to top it off. Thickens the 5w30 a little but not by a lot.
08 C702.5T (sold)
The non-Swedes:
MoVolvos
Post by MoVolvos »
Krons wrote: 17 Oct 2023, 17:44
I went the opposite direction. 5 qt 15W40 T6 and 1 qt 5W50 Castrol. I should have gone all 15W40 as the engine seems to be doing well with the thicker oil. Winter will tell.
