The door chime is no longer ON when I inserted the key before starting the car, door was closed. It used to have chime for about 10 times and then stopped or chime would stop when I start the car. Now, no chime at all. When door is open, chime is working fine.
Any suggestion is appreciated.
Thanks.
95 850, no more door chime when key is in before starting car
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Maybe you need to replace the chime. It's a little blue box that looks like a relay, and it's located next to the steering column under the dash.
I have a box of about half a dozen of these, because the very first modification I do when I bring another Volvo home is to yank these annoying suckers out
I travel to Boston frequently, if you want me to bring you one, let me know.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
lcc014
- Year and Model: 855, 1995
- Has thanked: 2 times
- Been thanked: 11 times
It turned out to be the micro switch inside the seat belt catch was broken. It is open all the times even after the seat belt is inserted. Chime relay is fine. The only way to fix this, I think, is to replace the seat belt catch.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I dont even know how you found that. I would never have tgought to check that.
lcc014
I found the wiring diagram of 855 wagon. The chime circuit has 2 branches, one for driver side door and the other went to a micro-switch inside the driver side seat belt catch and then to ground. This was for seat belt reminder purpose. Once seat belt is inserted into the catch, micro-switch will be in open state and stops the chime. Seat belt catch cannot be disassembled so need to get a new or used one.ZionXIX wrote: 28 Oct 2023, 06:24 I dont even know how you found that. I would never have tgought to check that.
You might be able to defeat it by removing the S terminal on the ignition switch electrical part, check the logic state of that to see if its NC or NO
- 1627 Views
Last post by pgill
- 573 Views
Last post by RickHaleParker
- 302 Views
Last post by CIK7
- 11 Replies
- 4362 Views
Last post by misha
- 791 Views
Last post by cn90
