Hi folks,
Is there such a thing as a *good* reliable scanner for a 98 S70 that's reasonably priced? Preferably either stand alone like an OBD-ii reader or a Bluetooth connection to smartphone (android preferred) +application?
I've used an OBDlink LX which has been reliable but not detailed.
I also tried an el-cheapo bluetooth obd reader and an app "850 OBD-ii" app which seemed to get details, but literally only worked once... I got excited because it worked and didn't take screenshots because I knew I could get back to it later...
I'm not interested in running a vm with VIDA/VICE if there's any alternative.
I'd really love to be able to reset the "service" light.
I am currently getting a code for an O2 sensor but can't tell which one.
I also have an issue with tracks/abs.
Does something like this exist, or am I being naive?
Thanks for any information you can provide, even if the answer is "no"
Affordable, stand alone(?) Code reader for 98 s70, NA automatic
- utilityaudio
- Year and Model: '98 S70 GLT
- Has thanked: 36 times
post up your codes on your OXS as they have completely different functions, and so only overlap on heater current faults.
AUTEL makes a good series of scanners and the one that will let you read codes and data runs about $150 on Amazon
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
I’ve used an iCarSoft one off Amazon and has worked well on my P1 and P2 Volvos.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Has thanked: 2199 times
My Autel resets the service light on the 96-98 cars. However, it is an 802 which is a higher end unit.
A laptop, a Vag-com cable and a free download of Vol-fcr will also do your checking, but is not really very portable.
I looked at the iCarsoft but it does not work on pre-00 cars that I recall.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
For $6 or $9 dollars you can obtain the most common codes and reset them. I have not tried the $9 iOS & Android. The free Car Scanner software is easy to use and full featured.
viewtopic.php?p=634816&hilit=obd2#p634816
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
So get a bit better OBD2 Bluetooth dongle? I bought the one that RobertDIY recommends, I think. It works pretty well for me.utilityaudio wrote: 28 Oct 2023, 22:13 I also tried an el-cheapo bluetooth obd reader and an app "850 OBD-ii" app which seemed to get details, but literally only worked once... I got excited because it worked and didn't take screenshots because I knew I could get back to it later...
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
I'd just look for a new/better BT reader and use the "850 OBD-II" app. It's pretty comprehensive.utilityaudio wrote: 28 Oct 2023, 22:13
I've had the same "cheapo" ELM-327 reader for several years, and it has worked for the OBD-II app, Carista, Torque, etc.
(I use the Carista app to get quick reads/resets, but the OBD-II give much more utility when I need it)
- 1204 Views
- 20 Replies
- 4733 Views
Last post by smacknab
- 980 Views
Last post by jonesg
- 11 Replies
- 1659 Views
Last post by hausmeister
- 15 Replies
- 3856 Views
Last post by rguzz
