It is only about 8-10cm long. It comes off the top of the turbo and connects it to the long metal pipe that runs over the top of the engine to the intercooler. I guess it is more of a collar.
In this Ebay picture, it is the short pipe coming off the top of the turbocharger.
https://www.ebay.ca/itm/144757775273
V70 2.4T High Idle after head gasket job
- Has thanked: 1848 times
- Been thanked: 1710 times
Re: V70 2.4T High Idle after head gasket job
Maestrours
- Year and Model: 03/2000 V70 XC 2.4T
- Has thanked: 29 times
- Been thanked: 9 times
Ahhhh sorry i was thinking about something smaller. Thanks i'll give it a look.
Maestrours
Idle is now ok since I changed injectors o-rings.
Always this smell on acceleration, just received my heat shield, i'll put it on the car and see if it change something.
If not, maybe ill need to give a look at the cat..
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
Check for an exhaust leak. Sometimes if you're burning a bit of oil, it smells rather raunchy if it isn't going out the tailpipe away from you.
Good thinking wizechatmgr. Look for manifold leaks and particularly the flex pipe join.
Maestrours
Hello ! I put the heat shield on the car today. 100 miles after, no more smell ! Will not underestimate the power of those pieces anymore !
- 1186 Views
Last post by goldmandan
- 67 Replies
- 9615 Views
Last post by wizechatmgr
