testing PCV
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Post by azureblue »
I read that a clogged PCV system will create a vacuum at the oil dipstick tube. Under idle at maybe 1K, I get a mild vacuum. At about 97K miles, does this mean I need to replace the PCV valve? Or is a mild vac Ok?
Thanks
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
A rubber glove over the oil fill after removing the cap should suck in toward the engine. Definitely should not inflate, or the pressurized engine will start pushing out seals.
If it fails this test you should change the PCV parts. What engine you have?
08 C702.5T (sold)
The non-Swedes:
azureblue
Post by azureblue »
it's a 2014 S60 t5, 5 cyl., , and this engine does not have a lip to attach a rubber glove to.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
Can you use a plastic zip tie to attach a glove to the oil fill opening? Or get a used cap and add a small pipe nipple to the cap?
azureblue
Post by azureblue »
There is no lip to attach anything to - the cap is flush. The dipstick shows a mild vacuum
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Krons
Post by Krons »
Don’t overthink the glove test, I’ve even laid a plastic shopping bag over the oil fill. If it sucks toward the engine you are good. Just don’t let it suck it into the engine!
:o
You just want to verify it has vacuum and the engine crankcase isn’t pressurized.
08 C702.5T (sold)
The non-Swedes:
azureblue
Post by azureblue »
Thanks - So if there is a mild vacuum at the dipstick, that is the same a vacuum at the oil filler cap?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Krons
Post by Krons »
azureblue wrote: 01 Nov 2023, 07:29 Thanks - So if there is a mild vacuum at the dipstick, that is the same a vacuum at the oil filler cap?
Never heard of folks using the dipstick verify the PCV is functioning. I’d pull off the oil filler cap and double check .
08 C702.5T (sold)
The non-Swedes:
