Hello there,
Anyone try this yet? Using a CNC machine to make car parts.
Some parts may be too hard to make due to the complexity.
Hardened parts would not be directly CNC-able, I think the approach here is to use softer metal for the CNC, then hardened, then use CNC grinding.
I worked in two different machine shops briefly long long ago, but forgot most of what we did. I do remember making bearings though, they were first made using softer steel, then hardened, then machined a second time. I remember some were hardened using a hot salt bath, and some were hardened using a carborizing pot. The final product pieces had to be randomly tested for hardness using a special machine.
Don't remember much more this was a very very long time ago.
For non-hardened parts this should work I would think.
CNC Your Own Parts
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
- Has thanked: 2199 times
There are those who may go that route. Then there is the option of small batch runs and finding somewhere that can do that. I did my last machining 45+ years ago. I plan to leave it that way! LoL!
The new way though is to 3D print stuff. You can even print metal, but not sure how strong the metals are?
- MrAl
Hi Neil,scot850 wrote: 31 Oct 2023, 15:41 There are those who may go that route. Then there is the option of small batch runs and finding somewhere that can do that. I did my last machining 45+ years ago. I plan to leave it that way! LoL!
Oh ok, ha ha. Yes it can be difficult sometimes but sometimes it may be difficult to find a part.
With my old, old, Hyundai, I had to make a new part that was part of the emissions control because there was none to be found anywhere. I used a metal pipe and some special high temperature epoxy, and used a part of the old piece that was still ok.
- Has thanked: 987 times
- Been thanked: 1075 times
MrAI,
Your comment on making bearings is interesting to me. I had always thought making bearings to be a specialty of bearing manufacturers. But I guess if you need a special size or design you make them yourself.
I have designed a lot of machined and heat treated parts, but not rolling bearings. Others did all the work to make the parts. But I learned a bit about their processes along the way. There is a lot of technology in both the design and the making of most machined metal parts.
It was very interesting and I made good money doing it.
If anyone needs some basic advice, I may be able to help.
I’ve been CNC parts for years, now.
Call Neil Canada......
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
I mean, unless you have access to an actual CNC machine (Which is kind of a general term, really), it's kind of cost-prohibitive for the average individual.
I've machined stuff, formed stuff, welded, had things laser-cut/water-jetted, and have made a lot of my parts over the years.
CNC work, like what Ben does at BNE Dynamics, requires some serious overhead.
He has some nice ball bearing m56 shift bushings!!Chuck W wrote: 02 Nov 2023, 18:02 I mean, unless you have access to an actual CNC machine (Which is kind of a general term, really), it's kind of cost-prohibitive for the average individual.
- MrAl
Hi Steve,
Oh really, what parts have you made in the past already?
I am just getting into this a little now.
- MrAl
Hi Chuck,Chuck W wrote: 02 Nov 2023, 18:02 I mean, unless you have access to an actual CNC machine (Which is kind of a general term, really), it's kind of cost-prohibitive for the average individual.
Well the price on some of these has come way down. You can actually get one now for under $200 USD.
I don't know if you could make something as demanding as a bearing, but I know you would be able to make other small parts.
For example, I do not know if you could make a wheel bearing with a cheaper CNC machine, but then again you'd probably have to buy the little steel balls that go inside, if that bearing used them.
- MrAl
Hi there,volvolugnut wrote: 02 Nov 2023, 08:17 MrAI,
Well one place I worked for a short time was actually a bearing manufacturer.
The heat treating process was very interesting. Until then I never knew one of the initial heat treating methods used molten salt where the bearings were dipped into the hot salt bath for a set time, then removed and quenched in water.
There was more machining after that too.
- 3111 Views
Last post by Rucho26
- 5434 Views
Last post by matthew1
- 66 Replies
- 6569 Views
Last post by MrAl
- 1589 Views
Last post by EuroDriver
- 31 Replies
- 5588 Views
Last post by VolvoOwl98
