air in power steering fluid 1990 Volvo 240
I have a 1990 240 with a power steering problem. Fluid bubbles when the car starts and bubbles for a while but will eventually stop. I have put a vacuum on the fluid reservoir and it will not hold a vacuum, I assume that there is air being sucked in somewhere. I cannot find an apparent leak, once the car is warmed up and running it seems fine, with no steering problem, where do I go from here? Thanks for any advice you can give me. JackN
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Have you tried flushing the system and perhaps use synthetic? If you think air is getting in perhaps add some ATP AT205 with the flush for the seals.JackN wrote: 04 Nov 2023, 19:51 I have a 1990 240 with a power steering problem. Fluid bubbles when the car starts and bubbles for a while but will eventually stop. I have put a vacuum on the fluid reservoir and it will not hold a vacuum, I assume that there is air being sucked in somewhere. I cannot find an apparent leak, once the car is warmed up and running it seems fine, with no steering problem, where do I go from here? Thanks for any advice you can give me. JackN
- 30 Replies
- 27064 Views
- 6091 Views
Last post by EngineeringBloke
- 506 Views
Last post by CC's xc90
- 4325 Views
- 2176 Views
Last post by lolafiona73
