rear muffler hanger rusted
2006 xc70 Rear muffler hanger, the 'branch' that holds the rubber coupling broke/ rusted from the muffler. That is, the metal rod that is welded to the rear muffler has rusted away. What can I bolt on to the tailpipe to then reconnect to the body hanger?
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
A photo will be needed so something could be created to improvise.AlanS wrote: 08 Nov 2023, 11:12 2006 xc70 Rear muffler hanger, the 'branch' that holds the rubber coupling broke/ rusted from the muffler. That is, the metal rod that is welded to the rear muffler has rusted away. What can I bolt on to the tailpipe to then reconnect to the body hanger?
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
The link below might be what you're talking about. If so, then all you need to do is to lift the rear, get an adjustable channel lock pliers and silicone lubricant spray and you should be good to go in under 10 minutes.
https://www.fcpeuro.com/products/volvo- ... t-30681626
- Been thanked: 504 times
- The FCPEuro link posted above is for the pipe in the middle.
- For the muffler itself, use a rebar (muffler shop has it)
and weld it to the body of the muffler. The other end goes
to the rubber hanger. I will take a photo and post it later...
- Been thanked: 4068 times
I put the end pipe one on Catherine the 2005 a couple years ago, from FCPcn90 wrote: 09 Nov 2023, 08:35 - The FCPEuro link posted above is for the pipe in the middle.
My 2007 S60..The tailpiece fix (on page 3 of the thread in the link below) just failed in one year.
viewtopic.php?p=636464
My 2006 S60...the previous owner had the local muffler shop did this repair using a rebar
as shown. In a way, this is a clever fix, I like it...
If you have a shop do it this way, make sure they support the weight of the muffler using a jack
or something before welding the rod in...
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Guys.. buy the bracket for $10 and be done with it … did it on both of my cars.
https://www.ipdusa.com/products/22096/R ... t-25432665
04s60 2.4
04xc70 2.5t
04xc70 2.5t
The bracket only works if the tail piece is still attached.
Even so, it is a bad place as it puts a strain on the welding spot. Bad factory design.
The photo I showed you above (done by the previous owner) should have been the factory design from day 1!
- 15 Replies
- 9971 Views
Last post by cn90
- 1185 Views
Last post by retrocycler
- 21 Replies
- 7113 Views
Last post by shiloh51933
- 806 Views
- 49 Replies
- 6633 Views
