I will be installing struts for the 00 S70 soon and will check to see if the upper knuckle hole is oblong. That would be nice instead of the camber bolt which I've yet tried. Can you provide a link to your spring compressor? Since it's free from Advance and it's 5 minutes from me I don't foresee getting a set but I like to compare the construction of theirs with yours.
The helmet and goggle are a good precaution. I guess I haven't felt the need for it but I did purposely unload one once I can see where that would be very protective.
Here's the spring compressor, It's from Princess Auto here in Canada, made by Powerfist which is their house brand. It's very robust and unlikely to bend or break, I've used it on larger springs also. It has a 21mm bolt and locking pins and compact enough that you probably could get 3 maybe 4 on a spring if you're uneasy with the job.
Strut bearing replacement 2003 XC 70.
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
2003 XC 70 (sold)
- Has thanked: 2205 times
I like the pins to contain the coils. When I was looking for this style years ago, there was nothing to be found like that.
My mechanic buddy bought a spring compressor off Amazon. It took a bit of fettling to assemble, but once done it worked well. I am still considering buying one at some point if I need to do any struts again, or just borrow his!
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.Blacklab467 wrote: 20 Nov 2023, 13:23 s.jpgsize.jpgSpring Compresser.jpg
That does look beefier than other compressors. I've Bookmarked it and hope to remember to compare it with the rental. Thanks.
- Has thanked: 311 times
- Been thanked: 817 times
Gloating about this one again, apologies. I paid $200 for this Branick 7200, found it on Craigslist from a local body shop when they upgraded. Have done about six sets of struts so far, it’s a dream.
viewtopic.php?t=78596&hilit=7600&start=1380
Originally I thought I’d use it and sell it but it’s a keeper for as long as I’m in the car repair trenches.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
The front spring seat has deteriorated, so it is time to assess the scope of work.
Yes, compressor is the elephant...
- Been thanked: 4069 times
You are down to $30+ per use, I think potato pie is in order to celebrate. That’s one hour of self-labour according to GAAPerikv11 wrote: 21 Nov 2023, 07:57 Gloating about this one again, apologies. I paid $200 for this Branick 7200, found it on Craigslist from a local body shop when they upgraded. Have done about six sets of struts so far, it’s a dream.
However , my AI server was unable to process content with ‘gloat’ and ‘Iowa’ in the same content , much like ‘happy’ and ‘Albany’
- 16 Replies
- 4357 Views
Last post by JRev
- 659 Views
Last post by precopster
- 1110 Views
Last post by oragex
- 1141 Views
- 1278 Views
Last post by Bluevanacd2005
