What could this noise be?
- Has thanked: 2203 times
These engines on the P2 can get loose exhaust manifold bolts/nuts which then causes a blow.
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
So, I got the spare brand new pump + gasket I had lying around but completely forgot the stethoscope.
Is there anything that could go bad if I run the car without the serpentine belt which will not spin the alternator.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
i drove mine home 40 miles when the acc belt broke,dikidera wrote: 22 Nov 2023, 08:44 So, I got the spare brand new pump + gasket I had lying around but completely forgot the stethoscope.
i made it and the car still had enough power to crank again when i got home.
dikidera
Late to the party but I just got back. I removed the serpentine belt, started the car and the noise was gone. I noticed the serpentine belt tensioner's pulley was first hard to turn and had no inertia to it at all, secondly it had some radial play. I am guessing it has gone bad. The alternator pulley was normal and I couldn't tell anything about the AC compressor. The PS pump had some slight axial play.
I reinstalled the belt, started the car and sure enough the noise was back. So while I can't say it's from the tensioner for sure, it is coming I believe from a belt accessory.
- 11 Replies
- 3794 Views
Last post by SUNRG
- 23 Replies
- 9606 Views
Last post by 2012
- 10 Replies
- 2382 Views
Last post by cmblackburn
- 2884 Views
Last post by pgill
- 1829 Views
Last post by Ozark Lee
