I believe I have VVT in this 2004 XC70.
Do I need the cam locking tool to replace a head gasket?
Head Gasket... Do I need the cam locking tool?
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Anytime you are pulling the timing belt it is good insurance to lock the cams. If a I recall right they aren’t too expensive of a tool.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
777funk
- Year and Model: 240
- Has thanked: 11 times
With my limited knowledge, I would have to ask on any Volvo. I know very little about which models require it which is why I posted the question.
Perhaps a better question, is when/when not is the tool a requirement?
For what it's worth, I do not believe I will be pulling the VVT hubs/pulleys. Only the cams out of their journals.
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
Vvt alignment is for when you've finished the repairs. Once you take the cams out you absolutely need the tool or A tool. Some people can and do make them at home.
How about the cam cover tool? You need that one as well, they are all part of the kit.
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
One bit of advice from experience - DO NOT crank the bolts of the tool down into the camshafts - snug is fine. You only need the big teeth to engage with the slots in the cams. The bolts are only 7mm and made of cheap steel, and I sheared one off INSIDE the camshaft. It became an ordeal to fix.
- Has thanked: 1614 times
- Been thanked: 4078 times
You can leave the hubs on the cams and then slide the seals from the rear of the cams to their position on the front of the engine. It’s not a textbook procedure but it works.
