Where can I find the repair manual for my engine? Head gasket.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
they went paperless and put everything into vida.777funk wrote: 24 Nov 2023, 19:58 I will be doing a head gasket. Is there a good place to find the mnaual for my engine?
ipd sells the uk Haynes manual, its ok but covers a lot of models and diesel too..
i learn more from youtube and vida than the book.
lots on ebay.
https://www.google.com/search?q=epd+%2C ... e&ie=UTF-8
- jonesg
AllData is better than the book, its by subscription , includes tsb's and diagnostic trouble flow charts, very good.
if you don't have vida then AllData is probably the next best.
https://www.alldata.com/diy-us/en?gad_s ... RYQAvD_BwE
777funk
- Year and Model: 240
- Has thanked: 11 times
Yes, why not. It's a matter of following procedure which is why I've asked for the manual. I do all my own work and have done for my entire adult life. I could probably wing it off of YouTube videos and forum published torque specs. I certainly could wing it on a non VVT model. It's not difficult to align marks. I would trust even my 16 year old (the owner of the car) with alignment of marks (crank and two cams). That isn't difficult. Same goes for torquing down a head. It's all about following instructions. And Cam cover... I've seen Robert DIY's method and it seems to work for him. He has enough experience (obvious by the amount of videos), that I trust what he does works.dikidera wrote: 25 Nov 2023, 01:21 Are you sure you are up to the task? I would advise getting a quote from a shop first.
However, it looks a little more complicated with VVT, which is why I do not want to go off of YouTube videos alone. That is unless someone can recommend one that can be relied upon for the VVT engine.
How much is Vida? I'd like to stay legal.
- Has thanked: 987 times
- Been thanked: 1075 times
The Haynes manual is pretty good. Sometimes amusing, since it was written in England. Engine removal and rebuild is covered. It covers models up to 2007. It also has lots of helpful information on body and chassis. I have used it a lot.
$40 direct from Haynes.
https://haynes.com/en-us/volvo/v70/1998-2007
