07 XC70 axle took a leak
Has thanked: 311 times
Been thanked: 817 times
Doing control arms this week(end?), the green wagon came to us with the factory original arms so just over 180k. Pics of those at the end of this post.
Not all pics are rotated 90˚ clockwise as compared to how I took them.
Why was the passenger axle full of water??? I've never run into that; probably 6-8 oz came out. Is the CV grease ok? The axle bolt threads were greasy on this side.
whaaaa?
whaaaa?
Here's how the job sits right now, taking a break:
one side disassembled
Car had no clear symptoms yet of failed control arm bushings but FYI this is what they looked like when I started the job ...
passenger's side bushings 1
passenger's side bushings 2
driver's side bushings 1
driver's side bushings 2
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
oh god.. Abscate is gonna have a heyday with this one.. *grabs popcorn*
04s60 2.4
04xc70 2.5t
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
melted snow in the boot.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Keep your old control arms, don't throw them out. Get some Volvo bushings and re-bush them and then you have a spare set for later. What brand of control arms are you installing? I've noticed some casting variations with the aftermarket brands I've seen, a couple of them appear to be cast iron or mild steel painted to look like aluminum.
2003 XC 70 (sold)
Yes, water got in, I just wonder how. Can't see any breaches in the CV boot. Car has not seen snow since last spring - why is snow more likely to blame than rain or puddle etc?
Anyone: would you regrease or replace the axle just because you saw all that water? At this point I'm thinking re-install and watch for noise, as always. Maybe time for an XC90 axle purchase/install.
The new arms are Lemforder (viewtopic.php?p=636853), they are not magnetic at all and the casting seems okay to my naive eye. But I hear you I'll hang onto the old arms for now, although if they go bad then I'm probably more likely to replace under warranty, we'll see!
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Those bushings are crispy! Should ride much better afterwards.
I’d probably throw a boot kit on it and re-grease it. When I found a torn driver side boot on my S60 during an oil change I bought a cheap aftermarket CV shaft to keep it going until I got time to re-boot/grease the old one. 10,000+ miles and I’ve yet to do that…maybe get to it this winter!
08 C702.5T (sold)
The non-Swedes:
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Yeah, can you verify they have good grease in them now? If so I’d put them back on for now. Maybe the water was a fluke / freak leak from when you drove through a stream??
Been thanked: 4065 times
br0dy519 wrote: 25 Nov 2023, 19:18 oh god.. Abscate is gonna have a heyday with this one.. *grabs popcorn*
It’s a P2, obviously
Ok appreciate the comments I will go ahead and button it up as is.
Has thanked: 2199 times
Been thanked: 1852 times
Can't think how water got into the boot. Did you buy the car new? Has the axle maybe been replaced with a junkyard one that may have had the end bolt removed and sat for a long time, possibly frozen when installed?
If the boot is good the only way for water to get in is through the bolt hole. Yikes.........!
