1997 volvo 850 ecc a/c control unit not working
I was wondering if you guys could help me try to figure out what going wrong with my car. So I was trying to fix the defroster on my car i took the motors out for the flaps for the ac and I took them apart and re-lubed them. And unstuck the flaps and put all the motors back into the car except for the one by the foot on the drive side and took a drive around town it worked great so the next day. I put the last motor back in and now my ac controller won't work the flap motor isn't responding the blower fan won't blow and there is no light on the ecc controller I check to make sure there is still power going to the cable to the ecc controller and I still get a 12-volt power and i took it apart to see if they're like a bad solder joint or something and I can't see anything bad inside the controller. I dont know what else to check unless the ecc controller died and since my car is 1997 i still need to build the led code reader that goes into the obd2 port to see if that shows anything but idk what else to do so thanks for the help.
built the code reader it just stays solid red. and won't respond to the button. and I was able to power the ecc controller outside of the car with a benchtop power supply and it had its lights on. so I'm guessing something in the car that is causing a short.
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
For a 1997 car, I am told that OBD-II works. (I have a 1995, and have to use the LED blink code under the hood.) If you have a reader available, you might give it a try.
Roger
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
ya, my code read works when I use it on another pin like the one for the ecu on the obd2 port, and if tried a reader with no luck. I know there is something wrong with the wiring going to the ecc controller cause I can power it outside of the car with a benchtop power supply and it turns on the lights for the ac and rec lights. But it won't in the car and when the plug is in that gives it the power to the ecc controller it makes my tester led stay solid red and my ecc controller won't turn on no light on the ac or rec light.so I think there is a short with the wiring going to the ecc controller.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'97 850 ECC still produce flash codes and readout is done via OBDII port with a blink code reader.Roger_850T wrote: 27 Nov 2023, 15:26 For a 1997 car, I am told that OBD-II works. (I have a 1995, and have to use the LED blink code under the hood.) If you have a reader available, you might give it a try.
Roger
Fully OBD II compliant ECC begins with s,v70.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
+1misha wrote: 27 Nov 2023, 18:11'97 850 ECC still produce flash codes and readout is done via OBDII port with a blink code reader.Roger_850T wrote: 27 Nov 2023, 15:26 For a 1997 car, I am told that OBD-II works. (I have a 1995, and have to use the LED blink code under the hood.) If you have a reader available, you might give it a try.
Roger
VIDA/DiCE can be hooked up for limited diagnostic, however it gives you all repairs and procedure to fix.
I miss mine, here is my history of 1997 Volvo 850 search.php?keywords=1997+Volvo+850&term ... mit=Search
Maintenance Log with references viewtopic.php?f=35&t=46831
xHeart
This was our 1997 850. I've many usable new and used parts; NOT junk. I'm happy to box and ship it to you for $1!nesman321 wrote: 15 Nov 2023, 07:59 I was wondering if you guys could help me try to figure out what going wrong with my car.
you would do that I would be grateful and that a nice looking 850 looks like mine but in a nicer condition
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
VIDA/DiCE won’t tell you much of anything on pre-‘99 cars. For ‘96-‘98 the 850 OBDII app is your best option for fantastic affordable diagnostics
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
xHeart
... we're grateful to MVS.
I'll pull it together and ship it to you after the holiday traffic -- includes repair manual and tools intended for our 1997 850.
Please PM me your shipping address when convenient, nesman321!
Happy Holidays!
- 2042 Views
Last post by brendonrobar
- 10 Replies
- 4987 Views
Last post by CRM
- 16 Replies
- 5192 Views
- 1967 Views
- 1599 Views
