Hi, We've been using a battery disconnect since we bought this car 3 years ago for my son, as in 3-4 days the battery will get too low to start the car. Driven everyday it's fine.
Today we went after the parasitic draw and are getting .45A..not milliamps... even with all the smaller red wires removed from the positive terminal. So whatever it is is feeding off the fat red wire that disappears under the engine.
Battery is good and at 12.8V. Charging is good.
Can anyone guess what's doing this? I *could* start tearing the car apart but ..is this common? Is it the diodes in the alt?
Big Thanks,
Andy
96 850 GLT .45A Parasitic Draw??
andyleonard
- Year and Model: 1997 850 GLT, 2005 X
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Time to use a multimeter and pulling out fuses...one by one...untill the drain stops.
Bad diodes would light up a battery warning lamp...even when engine is off.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
andyleonard
This one has nothing to do with fuses or the smaller red wires. Tried them. I'm getting the .45A from just the fat red wire to the starter area and the ground.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
That "big fat red wire that disappears under the engine" goes to the starter. (and alternator)
- Has thanked: 1611 times
- Been thanked: 4073 times
It’s almost certainly a bad alternator diode draw
andyleonard
I was afraid of that. I guess I was hoping they picked up power for something else underneath at the starter connection that was unfused.
- 85 Views
Last post by andyleonard
- 9 Replies
- 3146 Views
Last post by Cees Klumper
- 10 Replies
- 2066 Views
Last post by pb49415
- 11 Replies
- 2700 Views
Last post by mecheng
- 2286 Views
