So...i'm an idiot, I removed the pcv breather hose (without photos) and am ready to reinstall it. I noticed there are two such holes to install it in, a lower and upper. The slotted guard on the hose seems to suggest the higher one, but there are marks on the lower that indicate the hose was previously there. If I try to put the hose on the lower, the guard pushes the hose away from making contact. I figured I would ask here and see as I dont want to have to do this twice and I dont have access to an already built engine.
1999 S70 Turbo ch-00353
Part # for hose 9470330
1999 s70 t5 banjo bolt which hole?
- Has thanked: 1613 times
- Been thanked: 4078 times
This is the coolant banjo off the PCV manifold that mounts on the rear of the cylinder head? I’ll snap a pic this morning
Well, not sure if picture helps. Let me try to scour archives , too.
It looks like the banjo threads into the head and the heater hose right below it into the block?
- Has thanked: 2215 times
- Been thanked: 1853 times
I just checked also, but it is hard to see on a built up motor with the turbo. However, mine is plugged into the lower hole as Abscate says.
- 983 Views
Last post by MoVolvos
- 1335 Views
Last post by DavidE7
- 1231 Views
Last post by oragex
- 2060 Views
Last post by precopster
- 15 Replies
- 6509 Views
Last post by vtl
