oldskool1962
Year and Model: 1985 240
Post by oldskool1962 »
does my 240 have a crank sensor used to trigger injectors?
oldskool1962
where is it?? or is it done differently is yes how?
oldskool1962
Need help trying to get my 240 up and running again injectors not pulsing. cannot see a crank sensor?? is it done from the distributor?
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
My Haynes 240 manual does not refer to a crank position sensor, but there may be one. I have never had this problem with any of my 240s.
I would start checking grounds of the injectors and the control module. Also look for any crumbling wires in the wire harness. Bad insulation is a common problem of these years on 240s.
oldskool1962
I have done a lot of checking have removed the whole engine harness untaped it checked for damage ohmed out the whole thing and reinstalled it.there was 1 slightly damaged wire which I repaired that was no to do with my no pulse at injectors
Bentley Publishers manual also does not mention a crank position sensor, but says computer gets speed signal from ignition to determine how long to spray fuel. This paper manual is very detailed and can still be purchased online last I checked.
You may want to post to the BrickBoard Volvo site since they have more 240 experts.
