Cold Concrete & Your Back
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Re: Cold Concrete & Your Back
Post by MoVolvos »
volvolugnut wrote: 07 Dec 2023, 08:24 Somewhere I have a foam kneeling pad that helps for knees. I also used it for a roofing job as a butt pad to cushion my hip while sitting on the roof.
volvolugnut.
Have a small dense memory type foam pad for the knees also. In NC the roof pitch are steep so the roofers use a large couch cushion on their knees so they don't slide off.
Has thanked: 1506 times
Been thanked: 3818 times
MoVolvos wrote: 07 Dec 2023, 09:25
Chuck W wrote: 07 Dec 2023, 07:12 I keep a supply of large area cardboard onhand at all times. I also have 3 pieces of some high-density foam sheets that I acquired from some packaging that I use as cushioning or mats, depending on what I'm doing. I've got a lot of miles and abuse on my 55-year-old knees.
My supply comes from Costco's detergent section. The ones that are layered between the products for stability during shipping are pallet sized 40" X 48". I just fold them and tuck them under the shopping cart and hopefully they don't slide out once or twice during my Costco run. Knees and lower back for me.
+1000 for repurposing, true recycling
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
That's what I need to find.... I feel old just saying that.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
The moving blankets let you roll them up for knee protection , too. I do keep foam pads around , too.
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 175 times
Post by dikidera »
You youngun's and your blankets xD
Jokes aside I worked out in the cold at the scrap yard for years. The wrenches would stick to your hand but you need to persevere, that engine won't get taken apart by itself.
My toes would get numb, brutal. The only heat was a barrel with old headwrests we lit on fire.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1001 times
Post by volvolugnut »
dikidera wrote: 08 Dec 2023, 06:06 You youngun's and your blankets xD
I am guessing you learned to love the smell of burning foam in the morning!
Sounds like a tough job.
MoVolvos
Post by MoVolvos »
454cid wrote: 08 Dec 2023, 03:34
Depending on your Kneeds one for each.
https://www.amazon.com/foam-knee-pad/s?k=foam+knee+pad
Ooof, sounds nasty. I remember pulling an axle off a vw bus at Rosens in Buffalo in 0F with a 40 mph wind coming off the lake in the 1980s
Wonder if that yard is still there.
On edit,,,,turned into a massive cleanup project next to the Ashland pits, all gone now. River Road in Tonawamda, ny
dikidera
Post by dikidera »
volvolugnut wrote: 08 Dec 2023, 07:47
It was more like oil with petrol and diesel, but mostly petrol. See the ground is pretty soaked now and it's giving off a smell. The burning of foam, barely anything but once in a while there are these seats and headwrests made of this dried off material almost like hay, but not exactly. That thing smokes a lot.
That burning foam was certainly good for you. Isocyanates, urethanes, amd a cocophany of cancerous chemicals nicely aerosolised for deep breathing consumption
