Sounds like the damper selecting cold hot air has given up. Bit surprising as there are two, for right and left.
You will have codes in the ECC control module if this is the case
07 xc70 no cabin heat or a/c
Most excellent!
dcmike
- Year and Model: 1998 V70R
- Has thanked: 2 times
Thank you for all the replies. My son's car is away with him in Northeast PA so I'm not near it.
The thermostat and new ETS are working properly. He did disconnect the battery for a while and reset the car. The fan operates properly, turning off and on as temp requires. The climate control still does not work properly. He ended up taking the car to a independent Volvo mechanic outside of Scranton. He does not have time for the car until after the 1st of the year. The mechanic thinks its a wire.
I did purchase a used climate control unit from EVV. Do you have to do anything special if we replace the control unit, like take it to the dealer for any proprietary Volvo reset?
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Engine fan runs constantly when A/C is empty, even in cold weather. It also runs when ECT sensor is faulty (or its wiring).
T-stat may affect warmth in cabin, yes.
If a P.O. have used any stop leak products, it stops all the "leaks" through the cabin heat exchanger the first thing.
HVAC has 5 motorized dampers, they go bad.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
before pulling the panel and unplugging connectors be sure to disconnect the battery neg terminal to prevent an SRS fault .dcmike wrote: 22 Dec 2023, 07:20 Thank you for all the replies. My son's car is away with him in Northeast PA so I'm not near it.
- 1090 Views
Last post by MDK
- 734 Views
Last post by Kach
- 581 Views
Last post by MarcM
- 26 Replies
- 5487 Views
Last post by dejanaleksov
- 26 Replies
- 4241 Views
