Checking my maintenance log it had been 2 years and 24,000 miles. I expect to pick up 2mpg on the highway lol.
- Krons
- Has thanked: 193 times
- Been thanked: 202 times
I apologized to my 08 S60 yesterday. I’m typically an over-maintenance guy but my weakness is engine air filters.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Has thanked: 1507 times
- Been thanked: 3824 times
They are 30,000 mile items but if you live in a dust bowl, 15,000 miles is better
Des Moines is Dutch for Dusty place , I think
- Krons
I typically don’t like to go more than 15-20k miles, but you are right it is all on conditions. While this car has is on a gravel road once in a blue moon that’s pretty rare. Been scratching my head on recent mpg drop of 1-2, hoping this helps…could be I’m driving into the wind more.
Oh—In the what did you do category I also installed a new hood gas strut as the old one was pretty weak at 15 yrs and 163k. Way more convenient than keeping a properly sized stick around.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
With SWMBO out at a Christmas party today, the weather and the telly being utter crap I decided it was time to return to the ‘fir tree clips’ for the wiring harnesses that goes over the cooling fan cowl. I should really have waited until I needed to take the fan off next time, however I just thought that the next time I have to remove the fan it would probably be when I was in a hurry and wouldn’t have time to make a tidy job of my replacement clips.
As suspected it wasn’t as straight forward as first anticipated. I had to remove the ‘fins’ from the clips as they weren’t flexible enough to go through the hole. I needed to find washers with a 6mm hole that were not going to rust away so decided to rob my piggy bank of 5p pieces and drill a hole in them. I had thought about melting the clip pin at the rear to hold it in place but decided that might not be the best approach so instead I used starlock washers.
Next time I need to remove the fan I only need to cut the cable ties, no more searching for fir tree clips the correct size
Clips cut, fins removed, rustproof washers made from 5p coins and starlock washers Location of where to fit the 5 clips View from behind once clips fitted View from front once clips fitted Close-up of clips in place Harness cable-tied in
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 114 times
- Been thanked: 264 times
In our country its unlawful to deface or alter currency so I would ask that you mail me several 5 pence pieces so I may do a similar job on my wiring.........just kidding, nice tidy job!
2003 XC 70 (sold)
- P80GLT
Yes stainless steel washers are £3.00 for a pack of 10 so 30p each, so I saved £2.75 using the coins. Probably unlawful here in the UK but Christmas dinner in the Bar-L would save me having to put up with relatives I see once a year...
- Has thanked: 1854 times
- Been thanked: 1714 times
We save another 30% using Canadian pennies here!
- P80GLT
Yes I could have saved an additional 80% if I used 1p coins, however they are not made from bronze alloy of copper any longer and modern equivalents are subject to corrosion in harsh environments due to being made from copper plated steel
vtl
- Year and Model: 2005 XC70
- Been thanked: 606 times
You guys overthink it. Beer caps is the way to go!
