Throttle Body Unit becomes a PITA Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
swatik
Year and Model: 2007 Volvo S40 T5
Post by swatik »
Aloha everyone.
Story short - bought in September 2007 Volvo S40 T5 (AT) with 162k miles on it with a couple of error codes (Throttle and Accelerator pedal) and a broken oil pan as a small project for myself.
- Oil pan replaced, no issues.
- Accelerator Pedal fixed. Some stupid fella plugged in connector to Throttle body upside down. After connecting how it should be Accelerator pedal DTC is a history. Never saw it again.
- Throttle body - have been fighting for 2 months, and almost lack of ideas.
Currently VIDA shows 4 errors related to Throttle Body Unit:
ECM 9200 TP sensor faulty signal
ECM 921C Throttle unit potentiometer 1 signal too high
ECM 922D Throttle unit potentiometer 2 signal too low
ECM 9270 Throttle valve - Faulty signal
ECM 92CC throttle unit signal too high
I disassembled the unit and noticed that tracks were too bad but it worked so I bought another one used. Installed it but nothing has changed. The new unit inside looks good (see pics).
  • I've checked wirings from TPS to ECM and nothing shorted. I've checked CEM module - no water damage, no rust, nothing. Replaced all fuses. Literally each one of them.
    I've checked pins on CEM and ECM - no damage.
    All pins related to Pedal/Throttle I slightly compressed (yeah, I know that terminals are bad and better to replace them).
    All CEM pins, CEM, ECM pins, TPM, TPM pins are cleaned.
    I thought maybe it is MAF, cleaned (with connector) but no results.
    All wires looks intact ...
but I still have these issues related to TBM and ''Reduced engine performance' notification on a dashboard.
Accelerator pedal tested in VIDA and shows 80% (I think this is fine, no?).
My last theory is that CEM is dying or dead, because when I read car with Vida and ignition ON everything is OK, but if launch a car 3/4 of a car's modules turn in red, dozens of DTCs, car behaves like crazy -wipers ON/Off, dashboard shuts off, ABS, SRS, Immo, Brake failure, doesn't give the key - all of these pops up but never re-appear after erase. Only if I read a idling car with VIDA.
Car is starting, idling OK, takes up to 1700 RPM max and no further. It is not like I can't take it to the repair shop. For me it is more like a challenge. I would appreciate any ideas where to look. And yeah, PCV is totally screwed - lot's of smoke comes from oil filling cap and timing belt side quite in oil but I don't think this might be an issue, however PCV is to replace also.
New used Throttle unit looks OK to me
IMG_0059 Large.jpeg (148.27 KiB) Viewed 1865 times
IMG_0060 Large.jpeg (138.16 KiB) Viewed 1865 times
VIDA + launched car = Anarchy
IMG_9902 Large.jpeg (165.36 KiB) Viewed 1865 times
IMG_9904 Large.jpeg (86.68 KiB) Viewed 1865 times
IMG_9905.MOV
(20.54 MiB) Downloaded 115 times
Becomes a pain
Becomes a pain
swatik
Post by swatik »
Fixed. Car is up and running.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
swatik wrote: 14 Dec 2023, 00:01 Fixed. Car is up and running.
Great. But what did you do to fix it?
swatik
Post by swatik »
volvolugnut wrote: 14 Dec 2023, 17:20
I bought used TBU on eBay but it also turned out bad. Then I just part out both units and assembled 1 with the best looking parts.
