Passenger back seat floor wet, no sunroof. C30 2008
Mikele82
Year and Model: XC70 04 + C30 T5 08
Has thanked: 30 times
Been thanked: 3 times
Post by Mikele82 »
Any idea why would back seat floor be soaking wet?
no sunroof on this C30 2008.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Check the rear side glass seals or the antenna on top. Water could also be coming from the rear hatch seal. Dry the entire area and use a leaf blower to remove any dampness and then use a hose to see how fast and or where it may potentially be coming in. Is the spare tire well wet also?
Mikele82
Post by Mikele82 »
Thanks,
rear tire area seems dry, seal look ok.
I read somewhere some bumper bushing is a culprit, but I cant figure which and how to access.
crazycat
Year and Model: 2005 xc70
Has thanked: 17 times
Been thanked: 6 times
Post by crazycat »
Is the front carpet dry? Could be a/c drain. Cowl vent? Front windshield pinch/lap weld seam? It might be really wet under the carpet. A thick molded foam layer is attached to the back of the waterproof carpet backing. My foam was holding a few gallons of water while my carpet seemed dry. Can you remove a couple trim pieces and peel the back carpet up any all?
Mikele82
Post by Mikele82 »
OH wow, big foam under the carpet, ill tri to get to it in the morning and see.
Front carpet is dry. ive been running a humidifier today, got out about a litter of water out things are not damp as before.
Hope i can solve before the next rainy days
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Door and truck seals can be checked with a thick strip of paper or plastic. Close the door on the paper strip and then slide the strip in, out, and side ways to find the area of no resistance and maybe the leak.
MoVolvos
Post by MoVolvos »
Mikele82 wrote: 16 Dec 2023, 18:20 Thanks,
If you aren't able to find it use some blue tape around the 2 back side glass before it rains. Glass shops use the blue painters tape to help hold the glass during curing of the sealants. Won't leave much residue. Do this for the antenna on top of the roof also. Could also wax the area before taping to help with potential tape residue.
