1994 850 rally style lights
Hsnow
Year and Model: 1994 850 Turbo
Post by Hsnow »
Hello! I have a 1994 850 turbo wagon, and I am looking around for options for rally style fog lights.
I've done some research, but so far have failed to find a mount similar to the one in the picture attached that would fit my 850. I live in an area with a lot of backroads and fog and I could use a lot more light at night. I also just think the rally style lights look really good on the 850 wagons, especially opposed to an led bar.
However in my somewhat brief research I have noticed that almost every light setup blocks the path of air into the engine. I know it may be trivial but I just think its a little silly to knowingly block the main path of air. I'm looking for a bracket kit, or some instructions on how to mount them lower on the bumper as well as recommendations on lights.
Thanks for whatever insight can be offered,
Hudson
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
From the picture...the only thing that is blocking air path is license plate.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
There is a factory bar / bracket for the P2 and P3 wagons that bolts around the license plate mount. I don't know if there was one for the P80s.
Lower is better for fogs, but then they get bashed by rocks sprayed off truck tires.
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
850 1994 year model had bracket 9134 679-1
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Look to Nordic Climates and their Volvo boards.
That three fixture setup is a quite popular in
Scandinavian countries.
Hsnow
Post by Hsnow »
BEJinFbk wrote: 19 Dec 2023, 20:25 Look to Nordic Climates and their Volvo boards.
xanthefin wrote: 19 Dec 2023, 17:27 850 1994 year model had bracket 9134 679-1
Thanks to both of you!
I'll do some digging in both of those areas and see what I come up with.
rrres
Year and Model: 1999 v70XC
Has thanked: 12 times
Been thanked: 34 times
Post by rrres »
Not on an 850 but great videos with details on mounting and wiring.
It's blowby
Hsnow
Post by Hsnow »
rrres wrote: 20 Dec 2023, 08:55 Not on an 850 but great videos with details on mounting and wiring.
Thanks so much for the video! It will definitely be helpful as a reference down the road
It also has me thinking that I can probably make a mount myself. I've found some measurements on a Swedish website (https://www.extraljuskungen.com/install ... -210-225mm) that I think I could copy without too much trouble.
Either that or I'll go outside and attempt to come up with something.
BlackBart
Post by BlackBart »
Do they typically use two fogs and a driving lamp?
DennisCA
Year and Model: 1996 850
Has thanked: 6 times
Been thanked: 66 times
Post by DennisCA »
I mounted them like this, albeit only two of them, modified license plate mount that I instead mounted the other way.
I will revise this mount this year, think I will use a square tube welded to the plate instead and make it so I can put three lights instead. I am not worried about the cooling, seems to work fine.
