axle stuck in axle 1996 850R estate
cincinnatikid
- Year and Model: 1996 850R
the left front axle is absolutely stuck in the transmission. we're afraid of ruining the trans if we attempt to force it too much. i cannot find any zip boots and have heard of a tool that exists that can stretch the boot over the joint, but cannot find that either. any help and or advice would be greatly appreciated.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Yeah, that DS c-clip can be a pain. I fought the last one I messed with.
I got lucky with a large flat screwdriver as a prying tool and got it to pop free. (my normal pickle-fork didn't work)
I've seen these axle popper forks and have thought about picking up a set. (CTA 4017 or equivalent) LINK
cincinnatikid
Thanks for the reply. I’ll look into the forks.
- Has thanked: 2197 times
- Been thanked: 1851 times
I have used a cold chisel to pop them loose. Main thing to watch is flattening the flange around the seal. Normally a couple of sharp taps with a hammer and the chisel pops it loose. Try rotation the axle as you do this as it can move the position of the clip that holds it in place.
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
- 865 Views
- 21 Replies
- 4774 Views
Last post by mecheng
- 1494 Views
Last post by TechnicALFA
- 1026 Views
Last post by dsharp
- 441 Views
Last post by bmdubya1198
