Either a vacuum leak or the switch is faulty. Best sort it out before it burns out the vacuum pumpweitau wrote: 20 Dec 2023, 21:59 Yes! that is the same sound that I hear. Except it's constantly running, not pausing as in your video. The brake pedal is stiff (with engine off), but since the pump is not pausing, I'm guessing there might be a small leak somewhere. Thanks!
Identify this part - fuel system?
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
weitau
- Year and Model: 2004 V70
- Has thanked: 7 times
- Been thanked: 2 times
Ok thanks! Merry Christmas!P80GLT wrote: 21 Dec 2023, 11:41Either a vacuum leak or the switch is faulty. Best sort it out before it burns out the vacuum pumpweitau wrote: 20 Dec 2023, 21:59 Yes! that is the same sound that I hear. Except it's constantly running, not pausing as in your video. The brake pedal is stiff (with engine off), but since the pump is not pausing, I'm guessing there might be a small leak somewhere. Thanks!
2004 V70 2.4L
weitau
I got my new thermostat housing today. I also looked at the location, and it's behind the power steering pump. Not easy to get to, and I don't have a set of Torx sockets unfortunately. But your tip to disconnect the radiator fan might tie me over until spring.jonesg wrote: 20 Dec 2023, 12:24yeh, thats it, the computer isn't getting a signal so it defaults to over heating engine and turns the fan on.weitau wrote: 20 Dec 2023, 11:25 Wow yes my fan is running as soon as the engine starts so looks like coolant temperature sensor. Is the sensor right next to the thermostat in that assembly?
you can unplug the cooling fan until you get a sensor otherwise the engine will cold.
You need a deep 18mm socket, chrome not impact.
drain 1 gal of coolant via the petcock on the bottom of the rad.
re-use the copper washer if it doesn't come with the new part, just flip it over. 20 minute repair.
2004 V70 2.4L
- Been thanked: 4068 times
Swing out to Long Island one weekend and we can get you rolling again in an afternoon.
Port Jefferson area.
weitau
That's mighty kind of you sir, sending you a PM!abscate wrote: 28 Dec 2023, 01:57 Swing out to Long Island one weekend and we can get you rolling again in an afternoon.
2004 V70 2.4L
weitau
About a month ago, my friend was driving my V70 in stop and go traffic. The weather has gotten warmer and I'd forgotten about the disconnected radiator fan. Long story short, it overheated and I had it towed to the shop where fortunately they found no issues with the cooling system. But I had them install the thermostat housing
2004 V70 2.4L
- jonesg
- Has thanked: 73 times
- Been thanked: 534 times
all afternoon, bah,abscate wrote: 28 Dec 2023, 01:57 Swing out to Long Island one weekend and we can get you rolling again in an afternoon.
i can do it in 2 hrs, come on over i'm only 600 miles north.
- jonesg
i've blown the top hose off twice and another overheat was the coolant bottle cracked.weitau wrote: 23 Mar 2024, 11:37 About a month ago, my friend was driving my V70 in stop and go traffic. The weather has gotten warmer and I'd forgotten about the disconnected radiator fan. Long story short, it overheated and I had it towed to the shop where fortunately they found no issues with the cooling system. But I had them install the thermostat housing![]()
weitau
Sounds serious! hopefully there was no other damage to the engine.jonesg wrote: 24 Mar 2024, 05:40
On a old Toyota, I learned the hard way that lifting the hood and trying to cool down the engine is not always a good idea, as the exhaust manifold would cool at a faster rate than the engine block... This was made worse because it was the middle of a Michigan winter.
Where is the radiator cap BTW? Most other cars have one of these.
2004 V70 2.4L
- 1258 Views
Last post by 93Regina
- 9 Replies
- 2380 Views
Last post by dconklin
- 730 Views
Last post by etf48
- 723 Views
Last post by FLXC90
- 9 Replies
- 2175 Views
Last post by Sommerfeldt
