ABS/TRACS OFF panel lights on. '98 s70 GLT
ABS/TRACS Off lights are lit up. Chilton's manuel indicates perhaps a wheel sensor problem. How to determine which wheel sensor LH/RH front or rear wheel is problematic? Or is it someother problem? Thanks for any advice with this braking problem. Car was in use when lights came on.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
You are not the first...
Here is a very good place to get info:
http://home.earthlink.net/~vicrocha/
He also does very good work!
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
I agree with the ABS module. Also, check out the thread for fixing this yourself in the repair database.
I agree that it's the module, but I'm not sold on DIY for the repair. Reading some posts on the subject, some of the pins are stated to require a lot of heat in order for the solder to reflow properly. I work in aerospace, and am NASA certified in soldering. Without knowing the scematic or what's under the board, I'd be reluctant to touch it with a soldering iron. As a matter of fact, Mine is out for repair as we speak with Module Master. It's $150 but has a d 5 year warrently and is fully tested, something the DIY can't do. Food for thought. P.S. don't forget to pick up your little #5 external torx lock socket to remove the module!
Rsterns
- 22 Replies
- 6234 Views
Last post by hausmeister
- 1824 Views
Last post by Matty Moo
- 2175 Views
Last post by rguzz
- 12 Replies
- 1891 Views
- 1807 Views
Last post by CDoore54
