2004 V70 Window moulding
weitau
Year and Model: 2004 V70
Has thanked: 7 times
Post by weitau »
My passenger front window moulding keeps rising out of the track rack each time I raise the window. I've tried 3M trim adhesive and it only lasted a few months.
Any suggestions?
Window moulding
Window moulding
Close up
Close up
2004 V70 2.4L
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
The rubber should be embedded with metal structure to shape and hold it in the groove / slot. Remove and pinch the metal narrower / tighter before re-installing.
jonesg
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
i sprayed mine with silicon lube to make it less "grabby".
weitau
Post by weitau »
These are great ideas, will try them tomorrow!
2004 V70 2.4L
weitau
Post by weitau »
It's been a while since my last post, but I finally got a permanent fix.
I looked at the moulding on the other side of the car. The front edge of the window moulding was tucked under the side mirror housing.
So I used a plastic pry tool, lifted the mirror housing just enough to slide the window moulding underneath. sprayed the moulding where it touched the glass with silicon, and called it a day.
2004 V70 2.4L
