Identify this part - fuel system?
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
weitau wrote: 20 Dec 2023, 21:59 Yes! that is the same sound that I hear. Except it's constantly running, not pausing as in your video. The brake pedal is stiff (with engine off), but since the pump is not pausing, I'm guessing there might be a small leak somewhere. Thanks!
Either a vacuum leak or the switch is faulty. Best sort it out before it burns out the vacuum pump
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
weitau
Year and Model: 2004 V70
Has thanked: 7 times
Post by weitau »
P80GLT wrote: 21 Dec 2023, 11:41
Ok thanks! Merry Christmas!
2004 V70 2.4L
weitau
Post by weitau »
jonesg wrote: 20 Dec 2023, 12:24
weitau wrote: 20 Dec 2023, 11:25 Wow yes my fan is running as soon as the engine starts so looks like coolant temperature sensor. Is the sensor right next to the thermostat in that assembly?
yeh, thats it, the computer isn't getting a signal so it defaults to over heating engine and turns the fan on.
you can unplug the cooling fan until you get a sensor otherwise the engine will cold.
You need a deep 18mm socket, chrome not impact.
drain 1 gal of coolant via the petcock on the bottom of the rad.
re-use the copper washer if it doesn't come with the new part, just flip it over. 20 minute repair.
I got my new thermostat housing today. I also looked at the location, and it's behind the power steering pump. Not easy to get to, and I don't have a set of Torx sockets unfortunately. But your tip to disconnect the radiator fan might tie me over until spring. :D
2004 V70 2.4L
Been thanked: 4065 times
Swing out to Long Island one weekend and we can get you rolling again in an afternoon.
Port Jefferson area.
weitau
Post by weitau »
abscate wrote: 28 Dec 2023, 01:57 Swing out to Long Island one weekend and we can get you rolling again in an afternoon.
That's mighty kind of you sir, sending you a PM!
2004 V70 2.4L
weitau
Post by weitau »
abscate wrote: 10 Dec 2023, 04:07 Don’t forget to zip tie your new / old part!
I replaced the part, but forgot to do this. Thanks for the reminder!
2004 V70 2.4L
weitau
Post by weitau »
About a month ago, my friend was driving my V70 in stop and go traffic. The weather has gotten warmer and I'd forgotten about the disconnected radiator fan. Long story short, it overheated and I had it towed to the shop where fortunately they found no issues with the cooling system. But I had them install the thermostat housing :-)
2004 V70 2.4L
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
all afternoon, bah,
i can do it in 2 hrs, come on over i'm only 600 miles north.
jonesg
Post by jonesg »
weitau wrote: 23 Mar 2024, 11:37 About a month ago, my friend was driving my V70 in stop and go traffic. The weather has gotten warmer and I'd forgotten about the disconnected radiator fan. Long story short, it overheated and I had it towed to the shop where fortunately they found no issues with the cooling system. But I had them install the thermostat housing :-)
i've blown the top hose off twice and another overheat was the coolant bottle cracked.
weitau
Post by weitau »
jonesg wrote: 24 Mar 2024, 05:40
Sounds serious! hopefully there was no other damage to the engine.
On a old Toyota, I learned the hard way that lifting the hood and trying to cool down the engine is not always a good idea, as the exhaust manifold would cool at a faster rate than the engine block... This was made worse because it was the middle of a Michigan winter.
Where is the radiator cap BTW? Most other cars have one of these.
2004 V70 2.4L
