My passenger front window moulding keeps rising out of the track rack each time I raise the window. I've tried 3M trim adhesive and it only lasted a few months.
Any suggestions?
2004 V70 Window moulding
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
The rubber should be embedded with metal structure to shape and hold it in the groove / slot. Remove and pinch the metal narrower / tighter before re-installing.
weitau
- Year and Model: 2004 V70
- Has thanked: 7 times
- Been thanked: 2 times
It's been a while since my last post, but I finally got a permanent fix.
I looked at the moulding on the other side of the car. The front edge of the window moulding was tucked under the side mirror housing.
So I used a plastic pry tool, lifted the mirror housing just enough to slide the window moulding underneath. sprayed the moulding where it touched the glass with silicon, and called it a day.
2004 V70 2.4L
- 671 Views
Last post by volvolugnut
- 1226 Views
Last post by Rattnalle
- 1189 Views
Last post by smeha
- 14 Replies
- 4766 Views
Last post by Metallo
- 1743 Views
Last post by JakeNZ
