Has thanked: 1506 times
Been thanked: 3818 times
I excise the number 666 from the Forum with a shot of Seafoam into the intake manifold ....
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
P80GLT wrote: 26 Dec 2023, 10:41 A most uneventful Christmas trip in the V70 this year, yes the wind was blowing a hooley as we drove north of Spean Bridge without incident as the car took it all in its stride on 23rd. Then to the 24th I went for a drive to Glen Nevis and Glenfinnan to get me out the house for a break...
That looks like New England! Along Appalachian range.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
vtl wrote: 28 Dec 2023, 10:22
A very long way from New England, the road into the base of the highest mountain in the UK
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
2008 S60 2.5T got a fresh oil change (5000 OCI) and transmission drain and fill with Valvoline HiMi Synthetic ATF as that’s what I’ve ran in that car historically. ATF looking good based on color—last drain and fill was 20k ago. 164,000 miles and running solid.
Last week the kids 2002 S60 2.4T got an oil change also at 190,500. 5000 mile interval oil was filthy for my liking, will go 3000 on next one. This engine while running well has been historically dirty/sludgy…cleaned it up a lot since I bought it at 150k for $1500.
Both got Quaker State High Mileage Full Synthetic and STP High Mileage Oil Treatment.
08 C702.5T (sold)
The non-Swedes:
P80GLT wrote: 28 Dec 2023, 16:38
What is Ben Nevis? for the win on Double Jeopardy!
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Those landscapes are beautiful @P80GLT I’m jealous
04s60 2.4
04xc70 2.5t
And the Creator so much loved the Scots she built a wall amd told the ENGLISH to not venture Northerly of that
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Did she have the Romans build the wall?
P80GLT
Post by P80GLT »
The Romans built it around 122AD to prevent them for being severely harmed, because we ‘the barbarian Scot’s’ were too rough for the soft southerners :lol: :lol: :lol:
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Skymongrel
Year and Model: 2023 XC90, S80 2007
Has thanked: 19 times
Been thanked: 19 times
Post by Skymongrel »
2006 XC70 (190k), after replacing a noisy serpentine belt tensioner a couple weeks ago, I detected a new noise. It was a rhythmic humming noise that would go away if I turned the car one way to load and unload the front tires. I replaced my front left wheel bearing and noise is gone.
1. Jacked up front end of car, both sides.
2. Removed Brake Caliper. And placed on a small stool.
3. Removed upper stabilizer bolt.
4. Removed both strut mounting bolts.
5. Removed axel bolt.
6.Removed ABS sensor and moved to the side.
7. Pulled wheel hub away from front strut while pushing axel out of the hub. Bungee'd up the axel to keep out of way.
Use caution when doing this so you don't damage CV joint rubber boot. Hard not to hit it!
8. Turning steering wheel, got better access to wheel bearing bolts and removed them.
9. Cleaned hub bearing recess surfaces and installed a new bearing. Reassembled and noise is gone.
Just wanted to add that I recently had a super loud rear end noise (the car) that would not go away by turning the car and loading/unloading the wheels. I indeed was the rear wheel bearing. It just didn't behave like the front one.
