Loud clicking noise on idle
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
Sometimes my Volvo makes a loud repetative clicking noise when idling. It seems to do it more when I have just started it up. If I rev it while stationary, the noise goes away above 1k rpm.
It also seems to get worse when the a/c compressor is running. Sometimes the noise cycles with the A/C. Other times I can hear it with the A/C off and, turning it on makes it worse. The A/C works well after I did the zip-tie/bread clip trick.
I also hear a similar, but non-repeating crack noise when pushing down on the passenger side (as if I were testing the suspension), but that could be a different issue.
With the belt cover off all of the pulleys look fine even when the noise is occurring.
Here are some videos that show the sound.
IMG_1091.mp4
(1.96 MiB) Downloaded 299 times
In this video, the noise stops when the A/C stops cycling.
IMG_1173.mp4
(1.02 MiB) Downloaded 221 times
What could this be? A failing A/C compressor? It has been doing this for a while.
2002 v70 X/C 288k miles
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
Try pouring a bit of of water on the serpentine belt and see if it stops temporarily.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Stethoscope or long screwdriver on VVT solenoids and listen. Also look at t-belt and serpentine belt tensioners, they shouldn't jerk violently. T-belt's one is a bit more agile, though.
gavolvoman
Year and Model: 2009 S60
Post by gavolvoman »
@02V70 Did you ever find out what caused the ticking noise? My Volvo is doing the same thing. 2009 Volvo S60.
Been thanked: 504 times
Post by cn90 »
- I'd stop driving the car if I hear that noise, then
- Check service records, then
- Check every single pulley involved by removing the belt(s)....
- PS pulley, Alt pulley, AC compressor pulley, tensioner pulley
- For the TB area: both pulleys, WP pulley
02V70
Post by 02V70 »
gavolvoman wrote: 08 Nov 2025, 00:28 @02V70 Did you ever find out what caused the ticking noise? My Volvo is doing the same thing. 2009 Volvo S60.
Yes, It was the belt tensioner. I have no idea why it was making that noise, but replacing it and the pulley that was on it fixed the issue. I noticed the pulley on the original tensioner was not rotating smoothly, so I replaced it, but it did not fully solve it until i replaced the tensioner.
