Connecting Volvo to Vida, through a virtual machine, what would be the disadvantage?
Cheeers
Using Vida On Virtual Machine - Any Disadvantage?
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
Cumbersome. A VM is a resource hog. Works perfectly fine directly on actual hardware even Windows 11.
It's just a roundabout way to run VIDA. Like writing a GUI in visual basic to track the killer's IP.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Who in 2024 has Windows as a primary OS? Why? What for?dikidera wrote: 09 Jan 2024, 05:13 If your primary OS is not Windows then sure. But if it is, I see no reason to.
In 2024 even nested virtualization (virtual machine in virtual machine on hypervisor) is not bad at all.
dikidera
It's been my primary OS since the early 2000s. I do occasionally use Linux and I am not a stranger to compiling kernels, I've done that quite a lot. But still Windows is my primary OS.
- Has thanked: 2856 times
- Been thanked: 1332 times
I had Vida on a VM (Mac, Intel) and Windows XP (yes this was over a decade ago) caught a virus. It was not salvageable via any reasonable amount of effort, so I nuked the whole thing with one button click. Poof. Problem solved.
I think then I cloned a sibling VM with a bare Windows install on it, installed Vida, and was back in business in just minutes of actual human time/effort.
If you think of VMs as disposable, this strategy can save time and headaches. But keep it just to Windows/Vida to make it easy to play to the strengths of this strategy. If you put lots of work/documents on the VM, and don't back it up, all the elegance and simplicity is absent, and you have all the traditional drawbacks of a physical PC you depend on.
But to answer your question directly -- no drawbacks, all the physical ports are "there", and have been since the 2000s. A VM with Windows will "see" peripherals just fine. That problem was solved long ago.
Oka
The laptop I am going to use will only be for VIDA (VirtualBox) and a car scanning software on host (Windows 10). Just those two only, nothing else.
Would anyone have a VIDA in a Windows 7 OVA or VDI file I can use?
Or, is there where I can download one?
Though the VirtualBox installed will be on Windows 10 Pro x64.
Cheers
Cheers
- 2863 Views
Last post by Sardine
- 2747 Views
Last post by nickbw898
- 1490 Views
Last post by ZionXIX
- 625 Views
- 1011 Views
Last post by precopster
