Help identifying parts - Many, many parts......Update!
Been thanked: 4065 times
I was going to say rear shock absorber nuts for those big boys but those are acorns
Could be AWD rear axle hardware? You had your clamshell apart so you got into a lot more than I did
Has thanked: 2200 times
Been thanked: 1852 times
It is possible, but I can't find a listing for a nut that large other than the one writing this!
Well thanks to help and suggestions from the great folk here, I have managed to identify a few more parts. Like the weird T25 headed threaded screw with like channels in the side of the threads. This turns out to be the screws for the fuel cap door hinge!
I also confirmed a longer T25 self-threading screw. Good suggestion from MoVolvos, it is one of the 4 bolts on the door speaker in an 850. The other 3 screws are short (about 10mm). I would have been unlikely to find that one!
There are a few others I have now identified and have been documented and filed!
So thanks again guys!
