Oil leak behind timing cover - 2007 XC70 170k miles
mtd240
Year and Model: 2007 XC70
Has thanked: 23 times
Been thanked: 7 times
Post by mtd240 »
cn90 wrote: 13 Jan 2024, 10:45 Sorry, missed your post saying you already replaced the Exhaust VVT.
Cam seals: brand matters, what brand did you use?
FYI: Corteco is the genuine mfg.
I use Corteco, zero issues.
The Intake VVT: check the play.
PS: When was the last time you checked the PCV system?
I used Genuine Volvo cam seals, so those should be fine.
Is there a way to check VVT endplay with the timing belt on? Assuming not..
For the PCV: I do a glove test every oil change. Still pulls a good vacuum. Is there a different test you’d recommend?
I just cleaned all the old oil off behind and below the timing cover. I’m starting to think this might all just be stuff I didn’t clean when I did the exhaust VVT — it’s been on there long enough to totally soften the plastic at some points on the outer cover (pliable like soft rubber now).
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it :lol:
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Has thanked: 311 times
Been thanked: 817 times
That glove test result gives you what you need to know: pulling vacuum so this leak is not due to crankcase pressure from clogged PCV.
The crank seal rarely leaks period. Don't think I would ever replace it preventively (never have, never (!) will ...).
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
mtd240 wrote: 13 Jan 2024, 13:31
cn90 wrote: 13 Jan 2024, 10:45 totally soften the plastic at some points on the outer cover (pliable like soft rubber now).
that might be a rubber seal. Clean it up and inspect closely.
