My brother's daughter's 850 suffered sun damage to the steering wheel in the CA to the point the wheel is crumbling. I have pulled a solid wheel which is harder than realized to find is decent condition. Now they are in CO it should be less of an issue.
The wheel is solid, but a little faded. Is there any way to re-color the wheel back to black that won't leave residue on your hands each time you use it?
How best to clean a steering wheel?
- Has thanked: 2200 times
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
- Has thanked: 987 times
- Been thanked: 1075 times
Cover it with the lace on wheel cover.
- Been thanked: 4067 times
Isopropyl alcohol ( rubbing alcohol) is best to remove the gummy feel
I don’t think you can use a v70 wheel on an 850 , can you?
The answer is yes you can, but you then have to swap the airbag over as well. This wheel is good, it has just discolored from the black/gray color where it was exposed to the sun. It is clean and not gummy, just areas of lighter grey. I would like to get it back to the original color ideally. Yet another investigative project.
I have been given a few good suggestions above. My niece is already using the cover.
Thanks for the advice!
Here is a question. Are the regular black steering wheels leather or vinyl? Mine is fairly clean, but has color loss, but it does not look like leather.
I think the dressier linrs of car were leather; GLT, T5 , R maybe?
Sooo, the standard Volvo steering heel is NOT leather or even pleather. It is a form of vinyl, so leather recoloring products do not adhere to them. I showed the wheel to an automotive interior repair shop and they are recommending I need to clean the wheel thoroughly with soap and water and then rubbing alcohol. Then to use an adhesion promoter, followed by a vinyl paint. These products do not allow the color to come back off on your hands. They suggested a paint supplier so I will visit them when I have time and see what products they suggest.
This should make an interesting project, but I may leak it until the weather warms up so the painting can get done outside!
- 642 Views
Last post by Olegs855R
- 1206 Views
Last post by 454cid
- 685 Views
Last post by AndMad
- 1223 Views
Last post by WillieEvans
- 12 Replies
- 5123 Views
Last post by bmdubya1198
