2002 v70 Replacing ‘Trip meter switch’ on DIM
Derek123
Year and Model: 1999 V70 XT 2002 v70
Has thanked: 3 times
Post by Derek123 »
It’s been a while guys. You’ve helped me hugely before with my 960 and my last v70.
My father has owned his 2002/2003 v70 since new (72000 miles).
Recently the dash board has developed a fault…
It intermittently cuts out, goes completely dead or freezes. Last week I drove 50 miles to a breakers who said they had some secondhand ones. When I got there we tried 2 and they were both dead, so I put the old one back in and worked fine until the following day.
It is mainly intermittent and if it does freeze or blackout completely I can normally get it back on by pressing the ‘trip’ button…
It seems directly connected to the button.
My question to you is can I take the back off to check/replace the trip button or can I somehow get some contact cleaner in there?
If not can anyone recommend an auto electrician in England to get this fixed?
Thanks in anticipation,
Derek
BTW I had to scrap my lovely 2000 v70 with no problems because of the ULEZ laws in London.
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Hi Derek,
It sounds like your dash needs a proper rebuild, the symptoms you are describing are typical. I don't know who does this kind of service in the UK, but there a companies over here that would do it.
One of them is this one:
https://europeanelectric.net/products
Apparently we have members who used them and they were satisfied. Shipping would be a bit of an issue, but if you can't find anyone...?
Good luck,
Dirk
P.S. Too bad about your 2000 V70, what a shame.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
npexcept
Year and Model: XC90 I D5 (275) 2003
Has thanked: 9 times
Been thanked: 23 times
Post by npexcept »
If you want, I can take a look (electrical engineer here).
Maybe reflowing the solder joints will fix the problem.
I repaired my instrument cluster which also had problems (2003 XC90).
And germany aint that far from the UK
Just because you're trash, doesn't mean you can't do great things.
It's called garbage can, not garbage can not.
Derek123
Post by Derek123 »
Thanks npexcept I’ll give it a few days first and see what happens
Derek123
Post by Derek123 »
850 LPT wrote: 29 Jan 2024, 09:25 Hi Derek,
Good luck,
Dirk
Thanks Dirk. I’ll see if anyone can recommend one here in England first
Antoine240bk
Year and Model: XC70 2.5T-2006 - 4C
Has thanked: 12 times
Been thanked: 30 times
Post by Antoine240bk »
I don't know if this would work for you with the brexit, but there is a compagnie in Germany ecu.de, they fixed a bad throttle on my V70 2000 , price were really reasonable. They do rebuild instrument cluster. https://ecu.eu
edit: https://ecu.eu/orderrequest-8.htm#UK-N ... and-Brexit Too bad that won't work with customs :(
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
Antoine240bk
Looks like there is few compagnies in the UK doing instrument cluster repairs.
https://www.essexrecons.com/?wpce_searc ... pe=product
Derek123
Post by Derek123 »
Antoine240bk wrote: 29 Jan 2024, 11:32 Looks like there is few compagnies in the UK doing instrument cluster repairs.
Thanks for that. I’ll call them tomorrow.
I was also hoping to hear from someone who has taken one apart and get their thoughts on the trip button.
Derek123
Post by Derek123 »
Thanks again Antoine240bk - I did use [url]https://www.essexrecons.com/? and it was repaired very quickly. I posted to them on Monday and received it back on Friday. I highly recommend Essex Recons and they give a lifetime guarantee on their fix.
Antoine240bk
Derek123 wrote: 13 Feb 2024, 03:46
Awesome! Glad it worked quickly. :wink:
