- Has thanked: 1613 times
- Been thanked: 4078 times
Soon you graduate to buying the part, putting it in the shelf, and doing the same.spinard wrote: 27 Jan 2024, 14:55 Looked at that messy seeping power steering fluid reservoir for the umpteenth time, and said "we should replace that"...for the umpteenth time.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I've watched a few Youtube videos on these things. I'm considering one for next year.... too cold to install one now, and the garage isn't clean enough any way.jonesg wrote: 29 Nov 2023, 15:54 kerosine/diesel heater for the garage, it uses a 12v battery for the combustion and fan, really puts good heat out.
normally i don't touch the volvo until winter is over, 5 months from now.
it sounds like a turbine jet spooling up.
highly recommend for freezing garages, $99 amazon.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
i watched those same videos too, measured my pipe at 2 3/8th, so I bought 2 1/2 " ,
it doesn't matter if it doesn't slip fit as I'm welding it in.
the ends on the flex pipe are softer aluminized steel, unlike the stock volvo pipe its very easy to expand with pliers.
- jonesg
that looks very similar to my recent blood test.Krons wrote: 27 Jan 2024, 05:40 Got oil report back from Blackstone Labs. Overall great for an engine with 164k miles, first sample I’ve pulled on this car. Yet to do coils, fuel level would seem to indicate they may help fuel economy.
- jonesg
my installation, cut a hole in the wall with a drill and sawzall , push the exh pipe through it.454cid wrote: 28 Jan 2024, 18:01I've watched a few Youtube videos on these things. I'm considering one for next year.... too cold to install one now, and the garage isn't clean enough any way.jonesg wrote: 29 Nov 2023, 15:54 kerosine/diesel heater for the garage, it uses a 12v battery for the combustion and fan, really puts good heat out.
- jonesg
i rotate the door panel so its upside down, its much easier to unplug the door connectors when you can see them.BlackBart wrote: 21 Jan 2024, 09:34 One of the two big electrical connectors to the armrest controls was not coming out, and I was not about to force it.
once i started to break the blue slider blocks they kept breaking because the actuator arms were bent..
a new actuator was around $60, swap the motor into the new one to save money, you just need 4 large steel rivets.
- Has thanked: 987 times
- Been thanked: 1078 times
Dorman makes decent actuator arm replacements, with and without motors. You can also use short bolts to replace the rivets and make the next change easier.
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Interesting - the arms could be bent. Hmm.. They are pretty flexible sheet metal.
- BlackBart
The evolution of this pattern of behavior is buy the part, put in on the shelf, forget you have the part, buy the part again....abscate wrote: 28 Jan 2024, 04:53 Soon you graduate to buying the part, putting it in the shelf, and doing the same.
- 12198 Replies
- 1684776 Views
Last post by RedBrickCollector
- 97 Replies
- 210475 Views
Last post by br0dy519
- 59 Replies
- 62551 Views
Last post by smacknab
- 7109 Views
Last post by xHeart
- 12349 Views
