jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
BlackBart wrote: 30 Jan 2024, 10:23 Interesting - the arms could be bent. Hmm.. They are pretty flexible sheet metal.
the only way to get them really straight is to remove, but at that point its a fools errand to reinstall the straightened arms.
jonesg
Post by jonesg »
delivered, v70 thermostat and better long hex drivers than the HF ones that I stripped out.
16F outside, maybe not today.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
volvolugnut wrote: 30 Jan 2024, 07:54 Dorman makes decent actuator arm replacements, with and without motors. You can also use short bolts to replace the rivets and make the next change easier.
ah ha...
https://www.dormanproducts.com/p-66334- ... origin=YMM
FCP has a Lemforder for $175, hand-crafted by artisans in Italy (!), a cheap ProPartsSweden (not from Sweden), a Vaico from Taiwan for about $65, and OE blue box for......$450..(oh, it comes with the motor).
Here's the Dorman for my car for $77...
https://eeuroparts.com/product/dorman-o ... gIRnPD_BwE
jonesg
Post by jonesg »
mine was less than $70 from fcp. made in taiwan for proparts sweden.
https://www.fcpeuro.com/products/volvo- ... c_EALw_wcB
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
jonesg wrote: 30 Jan 2024, 11:56 delivered, v70 thermostat and better long hex drivers than the HF ones that I stripped out.
Let us know if those long drivers do the job in reaching that bottom thermostat housing bolt? I couldn't loosen that last time I tried so I just exchanged the thermostat alone. Still got the housing, gasket, and new bolts ready to install.
If they do work attach a link to them.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
I have had the most trouble replacing window regulators when I had to swap motors. It seems the motors have an internal stop that prevented it from continuing to turn until it reached the top or bottom of the window. At least it appeared that way. I had to remove the regulator, remove the motor, turn the motor to near the stop by plugging into power, and then reassemble with the regulator near the same orientation.
Try to install the motor on the new regulator in the same position as you remove from the old regulator (frame).
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
BlackBart wrote: 30 Jan 2024, 10:26 The evolution of this pattern of behavior is buy the part, put in on the shelf, forget you have the part, buy the part again....
For me it is: buy the part, put it on the shelf, can't find it in a year, buy again.
BlackBart
Post by BlackBart »
"I was just SURE I had a bag of those black door panel clips here somewhere!..."
vtl
Post by vtl »
BlackBart wrote: 31 Jan 2024, 13:34 "I was just SURE I had a bag of those black door panel clips here somewhere!..."
Oh yeah, I moved a year ago and can't find ANYTHING.
npexcept
Year and Model: XC90 I D5 (275) 2003
Has thanked: 9 times
Been thanked: 24 times
Post by npexcept »
vtl wrote: 31 Jan 2024, 13:42 Oh yeah, I moved a year ago and can't find ANYTHING.
Thats why I'm storing about everything in the trunk.
Plus side, I know where to search
Not so good: forgetting about the junk in the trunk and doing a brake test (today I replaced the brake hoses and pads + parking brake pads) and now it's all scrambled eggs
Just because you're trash, doesn't mean you can't do great things.
It's called garbage can, not garbage can not.
