You can emulate the serial port i think, but i dont know anything about those cables so is there anything that i need to look for?misha wrote: 04 Feb 2024, 10:09That might be the problem since Vol-FCR works only on serial (db9) cable and laptop or desktop with serial port.perhss70 wrote: 04 Feb 2024, 09:03 https://www.amazon.de/-/en/7170/dp/B00E ... 143&sr=8-1 should this work with vol fcr?
There are members on volvospeed.com who managed to make it work with usb cable.
Tracs abs speedo issues
perhss70
- Year and Model: s70 1997
- Has thanked: 6 times
- Been thanked: 3 times
'97 S70 2.0T5
- misha
- Has thanked: 155 times
- Been thanked: 432 times
It's also designed to work with old WinXP.
Owners who managed to make it work with usb cable...also have succeeded to make it work with Win7 & Win10.
Don't know anything beyond this since i'm keeping old desktop with serial port and WinXP in the garage for this purpose.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
perhss70
you can emulate com port i think but should i look for a specific cable? I have no idea on how they work.misha wrote: 04 Feb 2024, 10:09That might be the problem since Vol-FCR works only with serial (db9) cable and laptop or desktop with serial port and on COM1port ONLY.perhss70 wrote: 04 Feb 2024, 09:03 https://www.amazon.de/-/en/7170/dp/B00E ... 143&sr=8-1 should this work with vol fcr?
'97 S70 2.0T5
- misha
As far as i know...VAG COM KKL is what you need.
Mine is serial,i got it along with software and it says Vol-FCR on it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Speedometer takes the signal from front abs sensors but converted through abs/tracs module...in your case...since a car is manual...just from abs module.
You also have abs sensors on both rear wheels but they...as far as i know...are not used for speedometer.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2215 times
- Been thanked: 1853 times
On my 2000 V70 the signal for speed is taken from the LHF wheel sensor.
Misha, great info as always!
- 1721 Views
Last post by kimthepilot
- 22 Replies
- 6209 Views
Last post by hausmeister
- 10 Replies
- 6158 Views
Last post by misha
- 13 Replies
- 2085 Views
- 781 Views
Last post by nullspacebasis
