Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Re: Vida CEM swapping
Post by vtl »
rkam wrote: 17 Feb 2024, 14:22 The ones I've checked have flashing pin codes set.
Two had the same pin, and one had +1 on all bytes.
How did you read them? IIRC Renesas erases the flash when the read operation is attempted on a locked down flash.
rkam
Year and Model: 14473_96090_XC7007
Has thanked: 5 times
Been thanked: 25 times
Post by rkam »
Changed firmware to read itself.
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
rkam wrote: 17 Feb 2024, 16:05 Changed firmware to read itself.
Are talking of M32C and its password?
rkam
Post by rkam »
Yes, but only in DiCE, not CEM.
xanthefin
Post by xanthefin »
rkam wrote: 18 Feb 2024, 11:36 Yes, but only in DiCE, not CEM.
Oh i missed that part of discussion yes.
I already thought Volvo started using else than default password on some CEMs.
vitalik2134
Year and Model: Volvo XC90 2006
Post by vitalik2134 »
If anyone is interested, here is a flash DICE@000000 read by orange5 for experiments
DICE flash 000000.rar
(62.04 KiB) Downloaded 131 times
vtl
Post by vtl »
vitalik2134 wrote: 19 Feb 2024, 08:56 If anyone is interested, here is a flash DICE@000000 read by orange5 for experiments
It has no flash pin code, so it can be read in boot mode.
Kravi80
Year and Model: S60 my09
Has thanked: 2 times
Post by Kravi80 »
Skavac wrote: 02 Feb 2024, 22:02 Anyone knows if CEM-L can be read with Orange5? I can see it supports M30855F, but I can't find a wiring diagram to connect the CEM to the orange 5. Reason I am asking because failed write with IOTerminal. Now CEM is dead
http://www.ddmauto.ru/programmatoryi/st ... c-m30855fw
Clk, busy, p50, p60 no need to be connected in M32C UART mode (in M32C SPI must be connected).
Chips adm... and 93c86 must be desoldered.
MrP
Year and Model: V70 2.4T '02
Post by MrP »
Hi guys I was wondering if the "brick" cem is possible to Crack yet? I read you need to keep the k line active but I haven't seen it being cracked yet and I read a lot. Through the posts.
WhizzMan
Year and Model: 2001 XC70
Post by WhizzMan »
MrP wrote: 26 Feb 2024, 04:45 Hi guys I was wondering if the "brick" cem is possible to Crack yet? I read you need to keep the k line active but I haven't seen it being cracked yet and I read a lot. Through the posts.
No. You need to remove it from the car and directly read the content on the bench and find the PIN in there. There is no known vulnerability in these that will make it doable to find the PIN in a reasonable time.
