radiator fan always on full speed
reigox
- Year and Model: 2004 v70
- Has thanked: 2 times
I had this problem like 4 months ago aswell, the coolant temperature sensor fixed it back then. It came back like a week ago, I changed the sensor again, but now it didn't fix it. What could be the cause?
- Antoine240bk
- Year and Model: XC70 2.5T-2006 - 4C
- Has thanked: 12 times
- Been thanked: 30 times
how is the refrigerant level on the air conditioning? It was fixed on my car with a refill.
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
reigox
I have no idea, gotta check that.Antoine240bk wrote: 19 Feb 2024, 03:17 how is the refrigerant level on the air conditioning? It was fixed on my car with a refill.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
If the ecm fails to detect signal from the coolant temp sensor it will turn the fan on.
Check the plug on the sensor.
A/C pressure switch can also cause fun to run if too low.
Make sure the defroster is turned off.
Does anything work on that car.??
reigox
hahah this car is such a headache, it was fine before i broke the transmissionjonesg wrote: 19 Feb 2024, 16:11 If the ecm fails to detect signal from the coolant temp sensor it will turn the fan on.
- jonesg
I think you need vida to sort it out.
Theres constant 12v at the fan, the small violet wire sends the signal to close the relay on the fan and draw the neg to ground which lets the fan run. The ecm gets signal info from the ect and the A/C.
Either one can run the fans.
Fan relay failure is also designed to run the fans.
Vida will show if the ect sensor is giving temp information.
Ejbdunes
- Year and Model: 2007 XC70
I had the same problem after replacing the thermostat/sensor assy. with non-OEM parts. Ended up re-installing the old OEM sensor, which solved the issue.reigox wrote: 17 Feb 2024, 17:47 I had this problem like 4 months ago aswell, the coolant temperature sensor fixed it back then. It came back like a week ago, I changed the sensor again, but now it didn't fix it. What could be the cause?
- 1950 Views
Last post by Earn_est_89
- 1171 Views
Last post by Stu70
- 1928 Views
Last post by fisker247
- 11 Replies
- 5014 Views
Last post by BlackThunder
- 18 Replies
- 4558 Views
Last post by ZionXIX
